E40D - Cold Slip?!
Old Dec 19, 2006 | 09:23 AM
Ilikebigtrucks's Avatar
Ilikebigtrucks
E40D - Cold Slip?!
So I was driving my truck up the on-ramp to the highway when I noticed I could split the needles with the converter locked. That is, I could get 200-300 more RPM and when I let off the throttle it would come back down to where it should be and lock again. While I was playing with this to see if it was my imagination the O/D light started flashing of course which confirmed it was not my imagination.. I panicked and took the truck to Aamco the next day. They did confirm a Lock-up Converter Slip code was stored. (I saw this on the scanner but I was pretty sure it would be there) Irronicaly on the Way to Aamco it was perfect. I could not get it to slip - and neither could the tech. The tech also thought the ATF smells alright - Not new but not burnt. So the pattern is - the thing slips a bit cold. It's perfect once it's even luke warm. Has anyone else noticed this behavior? Should I really spend $1600 on a rebuild right now? =) Most people might not even notice this but I don't listen to the radio much and watch gauges like a hawk. Considering how good the transmission works Once it has been driven for a few minutes - If anyone else had noticed this I might consider leaving it.
Old Dec 19, 2006 | 09:35 AM
tjbeggs's Avatar
tjbeggs
change the fluid and reset the computer and see what happens
Old Dec 19, 2006 | 09:51 AM
firemanp's Avatar
firemanp
mine dont slip but I have a chatter between 35 & 50 mph in OD... kick it out of OD and its fine.. you can drive through the chatter but it is sure annoying... same thing with the fluid looked good smelled good but there was alot of debris in the pan.... havent had codes checked though and no blinking OD light...what else can you ask for with 202,000 on the clock..
pat
Old Dec 19, 2006 | 06:06 PM
trike1946's Avatar
trike1946
Is it a stock trans? How many miles?
I vote with tj, change the fluid and filter and see how it does. I think the fuse is number 9 to reset the computer.
Old Dec 19, 2006 | 11:40 PM
ech0sh4y's Avatar
ech0sh4y
I was told ( i know it's a myth ) that tranny fluid shouldn't be changed if the vehical has over 100,000 miles on it? I have 164,000 and my tranny fluid looks pretty nasty... is it safe to still do it? Are there any special fluid brands to run in a psd?
Old Dec 20, 2006 | 04:27 AM
trike1946's Avatar
trike1946
Has it ever been changed?
I use synthetic in all mine. I tow a lot and it runs cooler.
Old Dec 20, 2006 | 06:17 AM
tjbeggs's Avatar
tjbeggs
I would change it. Like trike said has it ever been changed? gotta believe it has been
Old Dec 20, 2006 | 07:16 AM
Ben-jamin's Avatar
Ben-jamin
Many transmissions may show their age through slippage, because internal seals start to harden then soften as they warm up. there are alot of pros and cons about changing the fluid on high milage trans. it wont take much to pull the pan and look in the bottom for excess fiber and metal, some may be present and still go a long time. if you still are worried about changing the fluid at least put a new filter and re-use the old fluid if it seems o-k. if u add new fluid you may have to put a shudder additive
for the torque converter.
Old Dec 20, 2006 | 10:09 AM
Ilikebigtrucks
I don't know about you guys but I've never seen a ATF filter with anything caught in it. My understanding is that the manufacturer specifically recommends the filter not be changed. I will change the fluid when I get a chance and see how it goes... Considering it works perfect once it's warm I'm not prepared to Tear it down just yet.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Dec 20, 2006 | 10:21 AM
95strokenonby's Avatar
95strokenonby
You may want to try Lucas Trans Fix fluid when you change the fluid. It will rejuvinate the seals and friction material to extend the life of the tranny. I use it during rebuilds. It also has properties that lower trans fluid temps which is real important on E4ODs.
Good luck with it.
Old Dec 20, 2006 | 11:17 PM
Ben-jamin's Avatar
Ben-jamin
the filter is there to trap particulate matter thats generated from the clutch frictions. after enough accumalation flow slows down and flow becomes marginal, enough so that the pump can't provide enough pressure/volume for the trans. to make a good clutch selection or apply.
my neighbor used that Lucas additive with good results , i like Lubeguard.
Catherine M Fisher
20
Nov 13, 2014 07:39 AM
83frankenstein250
Jun 7, 2014 06:40 PM
surfpunk
Jan 15, 2012 06:13 PM
TommyZ1
May 1, 2009 07:14 PM
jepps
16
Dec 26, 2006 11:25 PM
