Gibbons IFS where or what are they?
Both the mustang frnt suspension and the chrysler (gibbons) were on 1955 F100s. I purchased both compleated. I like the chrysler because it is adjustable. You can change ride highth and, more important, can adjust side to side highth. Both ride fine. darrellmed(No Email Addresses In Posts!)
Sacramento Vintage Ford sells them (you guys should get some vendor catalogs-yes you have to pay for some of them but they are very informative) and the raw crossmember kit for the Gibbons is $50.00 higher than the mustang II. But, the mustang has dinky brakes (9" discs) which people usually upgrade which =$$$. The coil over shock you mentioned is an upgrade which = $$$. I keep reading the mustang II's for trucks are wider than others and require special extensions which = $$$.
I have a 57 F100 which is a wider frame than the 53 - 56. The widening kit is $150. I plan to buy a Fat Man Fabrications unit. I will have about $1100 in everything (Mustang donor parts, ECI brake kit, Power steering, and Crossmember kit). I feel that the Mustang parts will be available for many years to come and they will be affordable due to its popularity. I'm not sure about the Chrysler parts.
My two cents worth!
Thanks Charles
My two cents worth!
Thanks Charles
denco
05-25-2015 05:29 PM
