Ford Diaster
Old Dec 29, 2006 | 04:24 AM
subford's Avatar
subford
Originally Posted by dstrick32
Purge Solenoid Valve is being actvated when ignition is in on position.
This should not be happing and is more than likely your idle problem.
I do not know any items to check for this and none of the T charts list this problem.
My only guess would be the PCM itself but I hate to go there.
The at speed problem could be the VSS and of course it could also be tied to the PCM if it is having problems.
Old Dec 29, 2006 | 10:13 AM
dstrick32's Avatar
dstrick32
I hate to have to go there also but I have found one more sensor that seems to be out of test range and possible short, it's the ECT and I do believe it controls the signal to the Purge Solenoid in someway. I'm gonna replace it and the fuel filter today hoping it solves at least some of the problems. Looks like someone has messed with the throttle idle stop screw, is there a certain position that it sets at?
Thanks for your reply!!
Old Dec 30, 2006 | 07:13 PM
dstrick32's Avatar
dstrick32
Changed out the ECT sensor and idle improved. Still getting a DTC 565 on the purge solenoid circuit but dropped the DTC 411 and added a TDC 212. Any takers??
Old Aug 4, 2007 | 08:55 PM
lostin90s's Avatar
lostin90s
Did you get your truck fixed? I hope you found problem . I'm doing the its running rich but still pinging hunt my self . Well I hope it works for you
Old Aug 5, 2007 | 08:35 PM
dstrick32's Avatar
dstrick32
Got it fixed after taking it to a Ford Mechanic that had the Star Tools to check for shorts in the wiring.
Old Aug 5, 2007 | 11:17 PM
Scndsin's Avatar
Scndsin
What exactly did he say? A shorted wire?
Old Aug 7, 2007 | 05:34 PM
dstrick32's Avatar
dstrick32
The spout and purge solenoid circuits were grounded on the negative side of the circuits.
bimmerbill
Jul 14, 2024 07:18 PM
Iceman5192
1997 - 2003 F150
Aug 15, 2013 09:54 PM
jdj0716
Aug 5, 2010 10:50 PM
302VAN
Apr 27, 2008 08:21 PM
dj8667
1983 - 2012 Ranger & B-Series
Apr 20, 2004 09:32 AM
