Ford Diaster
Old Dec 18, 2006 | 07:24 PM
dstrick32's Avatar
dstrick32
Ford Diaster
Well I'm working on a Ford F-150XL 5.0 Automatic and need your assistance. Runs better but still stumbles at idle and when driving at steady speed below 50MPH or slowly pressing the accelerator it starts to shutter, as if losing ignition or fuel (off & on) but if I give it the gas it smoothes out and accelerates fine. Check timing and it's dead on 10 degrees BTDC as label calls for but after putting the stunt back in and restarting engine it seems to retard timing and idle will shutter until it advances back up and it will do that in cycles. Still holding the following TDCs:
Code 411-Cannot control rpm during KOER low rpm check
Code 565-Canister purge circuit failure
Blocked off vacuum to the purge valve and no change but the purge valve is opening at idle. Purge valve circuit getting proper voltage. Checked grounds under hood and they are intact and showing a good reading. Where else would you go? So far this is what has been changed:
TPS
IAC
Stator Assembly
Ignition Module (remote mounted on driver's side fender)
Plugs
Wires
Distributor Cap
Rotor
Please help me get this thing out of my yard!!
Any ideas out there in Ford never land??
Old Dec 18, 2006 | 07:55 PM
Toyman's Avatar
Toyman
I had a similar problem on a 94 5.8. It ended up being a broken valve spring on the exhaust side of the #5 cylinder. If you can slide a test light in the individual plug wires at the cap, this should isolate which cylinder is giving you the issue. From there you can pull that vavle cover and take a look. If it is easier to just pull the covers and visually inspect save the test light step. Look carefully at the spring if broken it will look like it shifted position at the head. Also take a look at the push rods for one that may be bent if the springs look ok.
Good luck and let us know what you find.
Toyman
Old Dec 18, 2006 | 09:44 PM
dstrick32's Avatar
dstrick32
Thanks will check it out!!
Old Dec 19, 2006 | 04:47 PM
Lone Wolf #2's Avatar
Lone Wolf #2
I know this won't be encouraging, but do a compression check. I had an 89 with the 5.0 and the exhaust valve and seat were burned for #8 and the wall between the intake and exhaust runners was cracked.
Old Dec 19, 2006 | 06:36 PM
lostin90s's Avatar
lostin90s
Same here on 2 F150 5.0 #8 valve. Both time had head checked and they just fixed bad valve . Rest all looked good and I put 50000 on one no problems and 100000 on other . Good luck
Old Dec 19, 2006 | 07:12 PM
dstrick32's Avatar
dstrick32
Get out of here with that kind of talk!! You all ain't helping my feelings a bit!! Lets hope that's not it. Doesn't really sound like a miss just shakes at idle and sounds like it's just cutting out at higher speeds when you level ut or slowly give it the gas. I was kinda leaning on the torque converter. It has shuttered in the past at shift points. Undone the MAF today and it seem to level out at idle in limp mode. What's the best way to get back there to the PVC??
Old Dec 21, 2006 | 12:14 PM
dstrick32's Avatar
dstrick32
Sorry that should have been PCV!!!
Old Dec 23, 2006 | 06:19 AM
Lone Wolf #2
I said it wouldn't be encouraging.
Old Dec 23, 2006 | 06:55 AM
subford's Avatar
subford
With those codes and it acting that way I would say you have a vacuum leak.
One thing that does sound bad is the purge valve opening at idle unless you have a high idle.
The purge valve should only open with a warm engine at hi-way RPM. This is controlled by the PCM with information from the ECT and CMP sensors. This also goes for the EGR valve.
Of course you would have high RPM with a vacuum leak.
RPM - Revolutions Per Minute
PCM - Powertrain Control Module
ECT - Engine Coolant Temperature sensor
CMP - Camshaft Position - AKA Hall Effect or Stator sensor in the Distributor
Old Dec 23, 2006 | 12:04 PM
dstrick32's Avatar
dstrick32
I'm gonna get out there and put a tach on it and see what it set at but was trying to figure out a tach hook up without cutting wires. Does the Ford have a tach hook up for testing purposes? Icould find nothing in the wiring diagram. This Christmas stuff is hindering my repair work!! Thanks and it does seem like a vacuum leak and I'm having trouble locating it. I can't get to the PCV, but it's holding a steady 16 pounds.
Old Dec 23, 2006 | 02:47 PM
Hendricksbus's Avatar
Hendricksbus
How about the throttle body gasket? I had an issue with that on my 5.0 in my Bronco!
Old Dec 23, 2006 | 06:47 PM
dstrick32's Avatar
dstrick32
I replaced the gasket when I changed out the TPS. Checked it with carb cleaner with no change in idle but thanks for the ideas and keep'em coming!!
Old Dec 24, 2006 | 04:40 AM
fonefiddy's Avatar
fonefiddy
Have you serviced the EGR? Sounds like it might be stuck open
Old Dec 24, 2006 | 11:55 PM
dstrick32's Avatar
dstrick32
Thanks for the reply but from all checks EGR is working properly. Pulled it and all ports and valve were clean.
Old Dec 28, 2006 | 09:50 PM
dstrick32's Avatar
dstrick32
TPS at idle position is .94 volts.
Idle is high around 1000 rpms.
Purge Solenoid Valve is being actvated when ignition is in on position.
Still showing 411 & 565 DTCs.
Vacuum steady at 17.
Compression test OK All between 145-150 psi.
Found vacuum leak at PCV and changed it out, seems to idle smoother but if you just crack the throttle it roughens up but give it a little more and it smoothes back out. Still accelerate great but will cut in and out at level speeds. It's so radical that it will jerk your head off and sounds like the drivetrain is fixing to go south.
