High idle problem.
Old Dec 18, 2006 | 12:05 PM
wicket187's Avatar
wicket187
High idle problem.
I have a 1994 Ford ranger 4.0L 4x4. When I first start up my truck it idles fine, but once it sits for a minute or so, it starts idling high. Once in drive the Idle is still high and I can do 30mph without touching the gas. Any helpwould be appriciated.
Old Dec 18, 2006 | 08:41 PM
Rags's Avatar
Rags
Could be a vacuum leak! Check all your connections at the upper intake & If it has cruise control, check the vacuum hose to the actuator. Also check the vacuum line to the PCV valve, it is hard to see but check for a crack in the hose.
Old Dec 19, 2006 | 09:56 AM
rubydist's Avatar
rubydist
If its not a vacuum leak, most likely its the idle air control (iac) solenoid - they have a tendency to get sticky and stay open too far, which makes the idle speed stay up too high.
Old Dec 19, 2006 | 03:18 PM
aquanaut20's Avatar
aquanaut20
Check for dirty throttle body bore, the butterfly may not be closing properly
