Sponsored by: Auxito
cigar lighter
Old Dec 17, 2006 | 11:14 PM
acbell98's Avatar
acbell98
cigar lighter
i own a 2001 ford f150 supercrew, 2wd 4.6L. i'm having problems with my power points. my cigar lighter works fine, and i've checked fuses and they seem to be ok. one day they worked and the next they didnt, but like i said, the cigar lighter is still working as far as heating up the lighter. even when i plug my cell phone charger into the cigar lighter it doesnt work. i would like some advice or suggestions on what the problem could be. thanks alot
Old Dec 18, 2006 | 11:45 AM
searay220's Avatar
searay220
Sounds to me the problem is in the 12 volt plug of the cell phone cord. Check the fuse on the end of the plug or take the cord to another car and see if it works.
Old Dec 18, 2006 | 12:44 PM
HomerWinzlow's Avatar
HomerWinzlow
Since you have both a power point and a cigar lighter just use the power point. I dont recommend using a lighter socket because the tabs are not made to use with power receptacles. I recommend if you have multiple items to power up in the power point then you need to get a splitter from Radio Shack.
Check all the fuses in the power distribution box and the main box. I believe the power points use a separate fuse. I know the rear one is in the under the hood power distribution box but Im not sure about the front one.
Old Dec 20, 2006 | 09:10 PM
actrojan11's Avatar
actrojan11
The front powerpoint is under the hood and the cigar lighter is under the dash. I assume the back PP is under the hood but I do think it is different than the front PP.
tesserra
Electrical Systems/Wiring
May 19, 2020 07:54 PM
FORD E-150
1997 - 2003 F150
Feb 28, 2015 07:43 AM
Piratetech
2004 - 2008 F150
May 12, 2010 07:27 PM
bishopgeer
Jan 23, 2010 04:42 AM
ghades
May 19, 2005 08:12 PM
