gunk in filter picture
Old Dec 18, 2006 | 01:46 PM
Phydeaux88's Avatar
Phydeaux88
It may well be worth the time and effort to pull and inspect the injectors because soap may well contain caustic contaminants, which could damage the tip and/or plunger mechanism
Old Dec 18, 2006 | 02:15 PM
luvemhot's Avatar
luvemhot
i was tld that the gunk went through the injectors but the truck is now running and left the shop. i will ask if the injectors were checked
Old Dec 18, 2006 | 02:44 PM
Phydeaux88's Avatar
Phydeaux88
Tell your friend to keep his fingers crossed.
He should also get the "stuff" analyzed incase of problems in the future that could result from this fuel.
Old Dec 18, 2006 | 05:09 PM
luvemhot's Avatar
luvemhot
My step son is the tool binder for the dealer; he showed me the pictures cuz he keeps telling me to stay away from the bio diesel, and i just started running it b-10, so now a am worried about my truck, going to change the filter tomarow and check everything.
I am going to analyzed to at work tomarow with some haz mat stuff
Old Dec 21, 2006 | 05:00 PM
Hamberger's Avatar
Hamberger
Originally Posted by Phydeaux88
I dont know what it is but I can tell you what it isn't. It is not "lard coming back out of the fuel".
Once the feed stock oil has been thru the transesterification process it would have repeat the process in reverse to recreate the feed stock. That would require recreating the conditions found in in the processor with all components, including glycerol, present in the right proportions.
The only way it could be lard is if the feedstock, including lard, was simply mixed with diesel and not processed.
Was your friend truly using BD or was he one of the "mix WVO and diesel together" crowd.
One thing I have found after I froze my B40 recently is that after the B40 re-melted into a liquid it left behind traces of a margerine like substance in my fuel filter. Freezing the B40 fuel definetely altered the structure of the biofuel. I am about 3/4 of the way thru the tank that froze. Probably will need to replace the new fuel filter once the tank is done.
What I have learned out of this is that it is important to keep Biodiesel from freezing.
Seb...
Old Dec 21, 2006 | 09:39 PM
Phydeaux88's Avatar
Phydeaux88
What I have learned out of this is that it is important to keep Biodiesel from freezing. Seb...
Good clean 100% pure BD would not leave that residue. The circumstances you describe do not contain the elements necessary to alter the structure of the BD molecule because to do that requires an input of energy and cooling actually removes energy from the system.
It is almost certain that the residue is a congealed contaminant, most likely FFAs or a mix of glycerol and FFAs.
Old Dec 22, 2006 | 12:30 PM
Wheatina's Avatar
Wheatina
I've seen some astonishing differences between the BD produced from palm oil vs. soy or canola oil. Do you guys think it's possible that the BD used in this case may be palm oil based??? It gels at a much higher temp than say canola, or even soy.
The gunk in that filter, looks very much like the gunk I saw at a BD demo a couple of weeks ago in the palm oil BD example.
We know that Seattle Biodiesel often uses palm oil imported from Malaysia...could the Idaho fuel dealer have gotten it from there??
Old Dec 24, 2006 | 02:01 PM
luvemhot's Avatar
luvemhot
up date on the guy who made the bio, he worked for the place who made it not the stinker gas station
also i think they were using soy oil, I will have to check agian
Old Dec 29, 2006 | 10:34 AM
kennedyford's Avatar
kennedyford
That is just what fab was saying about the companies in California. They didnt finish the process and there is partial soap or glycering left over. What is the temp at that location just out of curiosity?
Old Dec 31, 2006 | 08:55 AM
luvemhot's Avatar
luvemhot
the temps have been in the 30 in the afternoon and 20 am
Keith
Old Jan 1, 2007 | 08:00 PM
kennedyford
Well now your getting in the type of bio diesel they are using and the temps they gel at. Mixed used oil turned to bio gels at a higher temp. Here is an example, fab has these actual numbers committed to memory
example soy bio gels say in the 40s
cannola in the 30s
corn in between and so on
Some places on I-90 and I-80 will not sell in the winter time because of this. Most 18 wheeler are used to adding antigel in extremely lower conditions then jacket weather.
Buck Fifty
2015 - 2020 F150
Apr 17, 2016 04:12 PM
fordf350man
16
Jun 8, 2015 07:32 PM
graduate
Mar 1, 2015 05:09 AM
Maravich12
Feb 26, 2015 06:11 AM
Shaskell008
1983 - 2012 Ranger & B-Series
Jan 16, 2015 04:25 PM
