gunk in filter picture
1 Attachment(s)
Here is a pic of a filter out of a Dodge, the owner was running B-10 from stinker Gas station in Idaho.
the same gunk was in the bottom of his fuel bowl, lost his injector pump to a cost of 2 grand. Why did it do this? I have run 4 tanks through my truck now , is there a need for worry? Thanks, Keith |
It looks like Vaseline. What does it feel like?
feels like it to
Does the cummapart sit a lot? Looks like it might be algae. Won't take 5 minutes for you pull your filter to see if it's from the stations tank or his.
its not algae. but the vasline compairson is a good one. I was told by the tool binder (works for the dodge dealer)it was the lard comming back out if the fule. the bottom of the fule bowl was full of the stuff. dont have that picture yet. but will get it and how many miles he had on it
Once the feed stock oil has been thru the transesterification process it would have repeat the process in reverse to recreate the feed stock. That would require recreating the conditions found in in the processor with all components, including glycerol, present in the right proportions. The only way it could be lard is if the feedstock, including lard, was simply mixed with diesel and not processed. Was your friend truly using BD or was he one of the "mix WVO and diesel together" crowd. |
that makes sence
could it be they did not refine it all the way?
Bio is supposed to clean the gunk out, but wow. I have a friend who has a 96 dodge and he didnt have any problems with bio, other than the standard run a few tanks though and change the filter issue. Was the bio purchased from a station? did they use a reputable refiner? B10 is not a common mix here. we have B5, B20, B80 and B99.
Put it in a zip lock bag and place it in hot water to see if you can get it to turn into a liquid.
came from stiker gas staion, the owner was one of the engineers for the bio diesel. they are reputable. they are the first gas station to sell any type of bio, was told that the b 10 was a test to see if people would by it
will see if i can get the filter and boil it. Keith |
Wow! In 3 years, and over 9,000 gallons I've never had anything like that [ but then I'm pretty anal about how I make my biodiesel]. I have small clear prefilters on all the rigs we use biodiesel in, and they always look very clear.
Looks like soap to me............ |
If its soap I wonder what the injectors look like
it took out the pump
will have more pictures tomarow cant get them off my cell phone untill then, it dont work in the mountains. |
