1955 F100 engine
Old Oct 15, 2001 | 09:38 AM
StantheCowboy's Avatar
StantheCowboy
1955 F100 engine
Thanks, guys, for the advice. I went ahead and hauled the truck home until I could decide what to do. From what I hear on this message board, it seems like the best thing to do is to find another engine. The block is cracked. The mechanic said I could have it sleeved, but I really don't know what that is. I'll try to classifieds here and e-bay.
I really appreciate all the help, guys. You've been great.
Old Oct 15, 2001 | 01:25 PM
Franklin2's Avatar
Franklin2
1955 F100 engine
That's why the rebuild was going to be so expensive. Sleeving a cylinder is alot of work and only worth it for an engine that can't be easily replaced. They hog out the cylinder and drive a sleeve (looks like a piece of pipe) down in the bore, and then bore and hone the sleeve for the new piston.
Old Oct 16, 2001 | 09:57 PM
StantheCowboy
1955 F100 engine
Guys, I have another question for you:
Do I have to put a 272/292/312 engine in my '55 F100, or can I use a modern engine with a little modification?
Thanks.
Old Oct 21, 2001 | 07:39 PM
texasbob's Avatar
texasbob
1955 F100 engine
You can definitely go with a modern engine and trans with a little work and modification. There are all sorts of kits available to help with swaps like these, especially for the 53 to 56 models. I only wish there were more goodies available for what I have, 1960 F100
Bob
Old Oct 22, 2001 | 08:18 AM
286merc's Avatar
286merc
1955 F100 engine
Thanks.
The 289-351 SBF series plus the FE 352 thru 428 all fit with kits available. Others prefer the 429/460 but its a tight fit for headers.
Old Oct 22, 2001 | 05:50 PM
rogerf100's Avatar
rogerf100
1955 F100 engine
Thanks.
If you use a modern engine plan on swapping out the trans also. You can use an automatic or a standard shift trans. Trans cross members are available for both. Just don't expect your old trans to bolt up to a modern engine. This will also require modifying the drive shaft for length and the correct yoke to mate to the trans.
rogerf100
Old Oct 23, 2001 | 09:28 AM
truckfarmer's Avatar
truckfarmer
1955 F100 engine
1955 ford f100
15
Jun 17, 2023 10:22 AM
jaggermk
Jun 1, 2015 08:12 PM
ccjackson75
Aug 27, 2014 11:15 AM
63flareside
Ford Truck Parts for Sale
Aug 7, 2014 11:51 PM
Good-Deal1023
Sep 1, 2010 02:30 AM
