AOD shifter hook-up
Old Dec 16, 2006 | 06:16 AM
lref1's Avatar
lref1
AOD shifter hook-up
I have installed a 351W and AOD in a 1955 f-100. I just purchased a Lokar floor shifter. The instructions say I must rotate the shifter arm on the transmission from the down position to the up position. I have looked at this arm and can not understand how to remove it to rotate it. Can anyone help me here?
Old Dec 16, 2006 | 10:00 AM
havi's Avatar
havi
I'll have the Roast Duck
guessing here, but you may have to drop the pan and filter, look up in behind the linkage piece, and see what's holding it in there. I can't say for sure, my AOD came from an 87 XR7, with factory floor shift. My 88 Tbird has column shift, but I haven't looked underneath the car yet. I had to remove the pan and filter to flip the shifter in my C6. Wasn't too hard.
Old Dec 16, 2006 | 05:44 PM
Huntsman's Avatar
Huntsman
I had the same problem with the 5.0 aod from an 89 f150. I had to drop the pan, loosen the large nut on the inside of the tranny holding the shift arm. Loosen it enough so that you can pull the shaft out just far enough to rotate the shift lever shaft. It has a fork inside that can be easily rotated 180* and tightened back down.
I had problems with the TV cable and had to modify my shift lever a little to clear it and prevent binding. Good luck and have plenty of oil dry on hand because I had a nice mess when I drained the fluid.
Old Dec 17, 2006 | 05:43 AM
Grabber's Avatar
Grabber
Huntsman would you happen
to have any pics of your setup?? if so could you please post them Thanks in advance
Old Dec 17, 2006 | 10:54 AM
Huntsman's Avatar
Huntsman
I shaped and bolted a piece of flat stock to the existing shift lever. A little bend will allow it to clear the TV cable mounting bracket. I am having an old age moment and can get an image to post so here a link to the photo in my gallery.
https://www.ford-trucks.com/user_gal...136369&width=0
Old Dec 17, 2006 | 07:50 PM
tip49's Avatar
tip49
AOD linkage
If the AOD is configured with linkages pointed down, to rotate the manual linkage 180 degrees, you must carefully drop the valvebody, loosen the manual linkage nut, and turn the lever 180 degrees. Then, tighten the nut, making sure the centering pin in the case remains and that both the manual and throttle valve (kickdown) linkages are properly reinstalled inside. Reinstall the valvebody and torque the 8mm bolts to specs.
I was considering using late 80's Thunderbird shifter but have opted for Lokar based on the cabling of T-bird facing wrong direction.
Tom
Old Dec 17, 2006 | 08:02 PM
Huntsman's Avatar
Huntsman
All aod's may not be the same but rotating mine did not require the valve body to be removed, simply to loosen a nut far enough to allow the lever to rotate.
My aod came out of a 89 F150 and even after rotating the lever up 180*, the lokar shifter would not work. The linkage interfered with the tv cable. I had to rotate the lever back down to the original position and bolt on a modified flat bar linkage, pointing up to make it work. If the tv cable was not in the way it would have worked as advertised by Lokar.
Old Dec 17, 2006 | 09:36 PM
Grabber's Avatar
Grabber
Thanks guys, i wasnt to sure what i was doing , im still unsure but am more knowable to this point, I will be using the Ididit Column with the Shifter Arm attached , non floor change.
Old Dec 18, 2006 | 11:11 AM
Okiedokie's Avatar
Okiedokie
Here is mine with column shift. i made an extension to acheive the "throw" needed to align as close as possible. Joe
Old Dec 18, 2006 | 02:23 PM
lref1's Avatar
lref1
Thanks guys. I think I will wait until I get the TV cable and maybe fabricate an adapter for the shift arm on the order of Joe Gaddy's
Old Dec 18, 2006 | 06:34 PM
tip49's Avatar
tip49
AOD Linkage Problem
Not meaning to hijack this thread, however :
I picked up my Lokar Midnight nostlagia shifter today; when installed I have two issues:
the shifter arm is inboard on the mounting bracket and hits on the mounting bracket
the shifter arm is almost directly above the arm on the transmission and is 6-7" inches above it, meaning I will have to modify the shifter arm, one by moving it outboard and two possibly lengthing it to drop it in line with the transmission arm.
Anyone else experience this, my transmission does not seem to be the same as some installs I have seen posted.
tom
Old Dec 18, 2006 | 08:47 PM
Huntsman's Avatar
Huntsman
Here's a link I found that might help...the linkage to the shift arm has swivel eye bolts on each end and does not have to line up directly with the shift lever. http://www.rodandcustommagazine.com/...ifter_install/
Old Dec 18, 2006 | 10:36 PM
tip49's Avatar
tip49
Lokar Article
Thanks Tom; I will try tomorrow
Tom
Old Dec 20, 2006 | 09:49 PM
tip49's Avatar
tip49
Lokar Installed
I was able to install the Lokar shifter today, needed to get email help from Lokar as the instructions were a bit vague. They made no mention that the linkage was 1 1/4" offline from the shifter; but I bent an offset in the rod linkage. I also had to re-position the shift lever on the shaft to accomodate my placement in the tranny. It seems to work fine, may need to adjust the neutral switch and modify the kickdown cable yet.I'd post pics but have not resolved my Java issue with gallery yet.
Tom
Old Dec 26, 2006 | 02:46 PM
lref1's Avatar
lref1
OK. I got a TV cable kit from Lokar and it mounts pointing down with the mounting bracket attached to the transmission pan. Therefore I had to reverse the transmission shift lever 180 degrees to the up position. As was explained in a to me before, I had to drop the transmission pan, loosen the large nut holding the shift lever in place, rotate the lever, tighten the nut and replace the transmission pan. Overall, this was not too difficult to do. With the TV cable lever in the down position there will be no interference with the shift linkage. The rest of the shift linkage install was straightforward. Because the shifter arm and the transmission arm are offset from each other, I had to bend an offset in the threaded rod shift linkage. I want to thank all those who replied to my original post as they were all helpful to me.
schoo
May 31, 2016 09:10 AM
schoo
Apr 2, 2016 09:59 AM
kdaug5
Nov 30, 2015 10:49 AM
kdaug5
Aug 14, 2015 05:13 PM
Poison Oil Racing
Jul 14, 2009 02:07 PM
