bearing preload
Old Dec 16, 2006 | 12:01 AM
sadiebill's Avatar
sadiebill
bearing preload
What type of noise could you expect, if any, if pinion bearing preload is incorrect? Truck is 2003 witha 3.55 ls differential.
Old Jan 5, 2007 | 11:19 PM
amish77's Avatar
amish77
What noises are you hearing? A low moan means you're out of place on the ring-pinion lash. Bearings usually schreech at you when they go out.
Old Jan 6, 2007 | 03:06 AM
sadiebill's Avatar
sadiebill
This noise starts around 40mph sounds like hum or tire noise under acel., but quits when you let off gas. It also sounds like a left front wheel bearing sometimes when coming to a stop.This all developed aprox 1000 miles after a pinion seal replacement and 3000 miles over warenty.
Old Jan 6, 2007 | 12:35 PM
bronco521's Avatar
bronco521
did you check to see if the pinion is still tight?sometimes after replacing the pinion seal, if the pinion nut isn't replaced with a new one they'll loosen up.
stan'37
Modular V10 (6.8l)
Apr 16, 2015 06:17 AM
Dennis/Ohio
Large Truck
18
Mar 13, 2014 06:09 PM
Jason6969
May 25, 2008 08:39 PM
polky
Oct 14, 2007 05:00 PM
fomoco
Jun 28, 2003 08:31 AM
