Modular V10 (6.8l)
Front wheel bearing preload
Old Apr 10, 2015 | 01:01 AM
stan'37's Avatar
stan'37
What is the proper way to adjust the front wheel bearings on a E 450? Thanks Stan
Old Apr 10, 2015 | 08:15 PM
Bently_Coop's Avatar
Bently_Coop
What do you mean adjust? Are these like unit bearings in a Super Duty? I haven't seen or heard of a way to adjust but havent searched either.
Old Apr 11, 2015 | 08:17 AM
JWA's Avatar
JWA
My rule of thumb for seating or preloading new front wheel bearings is tightening them until the wheel won't spin, loosen and repeat one more time.
After the second time torque them to no more than 15 ft/lbs and you should be good to go.
As a precaution after driving about 50-75 miles recheck for overly tight or loose bearings, wheels off the ground naturally.
HTH
Old Apr 11, 2015 | 02:33 PM
projectSHO89's Avatar
projectSHO89
When in doubt, read the directions.
Old Apr 11, 2015 | 11:43 PM
stan'37's Avatar
stan'37
I wish I had the directions. Until I have the directions, I was hoping someone would give me a hand. That is all I wanted. Stan
Old Apr 12, 2015 | 12:34 AM
Tedster9's Avatar
Tedster9
Originally Posted by JWA
My rule of thumb for seating or preloading new front wheel bearings is tightening them until the wheel won't spin, loosen and repeat one more time. After the second time torque them to no more than 15 ft/lbs and you should be good to go. As a precaution after driving about 50-75 miles recheck for overly tight or loose bearings, wheels off the ground naturally. HTH
This. ^^ NEW tapered roller bearings/race installation actually require way more preload and torque compared to USED bearings (just getting an inspection/repack.)
What usually happens then, is peeps install new bearings too loose, though the used bearings end up being adjusted too tight. Not the end of the world but it's worth doing correctly.
Once bearings have run in a little bit bearing adjustment only requires the spindle nut little more than hand tight. It's kind of a "feel" thing, while spinning the wheel. All the major bearing manufacturers like SKF and Timken have installation instructions too. If you dig around they are free, in .pdf form available for download.
Old Apr 12, 2015 | 06:47 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Come on guys, give the guy a hand... anyone got a shop manual/CD laying around?
Old Apr 15, 2015 | 06:26 PM
300sflyer's Avatar
300sflyer
What year is your truck? I have an 08 FSM I can look up for you.
Old Apr 16, 2015 | 06:17 AM
JWA's Avatar
JWA
When I checked my CD-ROM factory service manual for this operation there was no published or specified procedure with steps required or torque values listed. IIRC there was mention only of "not too tight or too loose" or something to that effect. That manual covered '97 E250 chassis.
I was a bit surprised or shocked that a factory manual didn't have something specific listed. My info posted here was from a long time mechanic running his own shop at the time, mid-80's.
abe
51
Apr 10, 2019 04:53 PM
busdriver47
Aug 10, 2015 08:44 AM
Ned Nimrod
Sep 28, 2006 11:07 PM
67halfcab
1983 - 2012 Ranger & B-Series
Mar 1, 2006 09:01 PM
