GPR question
Old Jan 6, 2007 | 06:35 PM
OfficerDangle's Avatar
OfficerDangle
Well i seemed to of found my problem with my truck, i cant use the gpr109 because its rotated 90 degrees so i couldnt use the bracket and shunt that were on the orignal glow plug relay. the shunt splits the left and right side glow plugs apart for testing or emission reasons(but still unclear). anyways if you have a late 99 california truck you need to either get the motorcraft replacment or the gpr110 or else you will throw codes. (only if u have the bracket adn shunt)
i also have one more question, since the sides are split up i tested the ohms on the brown wires for each side that go to the glow plugs and they both came back with .2 ohms. so i assume my glow plugs are good. is this right?
if your curios to what the bracket and shunt that attach to the gpr looks like i have a pic in my gallery.
Old Jan 6, 2007 | 06:53 PM
Uzumati's Avatar
Uzumati
Good to hear ya got her sorted out
For the record: About a week after your post we had an early 2000 Cali truck with the relay and shunt.
Old Jan 6, 2007 | 08:36 PM
kbeefy's Avatar
kbeefy
Actually, that just means you have at least one good glow plug on each side. If you really want to know, you need to pull the plug at the valve cover and ohm out each wire.
ved0303
May 5, 2015 11:30 PM
HollowayDoc
32
Mar 20, 2015 03:49 PM
Rusty_S
Jul 18, 2014 07:25 PM
BlueOvalBud
21
Mar 1, 2010 05:54 PM
