2002 X stalls engine when put in reverse??
Old Dec 14, 2006 | 06:28 PM
502builder's Avatar
502builder
My 02 V10 X has 130,000 faithfull miles with no problems, But here lately it has been stalling about 60% of the time when shifted into reverse. The engine is well overdue for a tuneup, it still has the original plugs and I have yet to clean the IAC valve, but it other than this problem it has been running like the day it was new. My question is has anyone else had this problem, and is it related to the transmission/ torque converter or the engine?
Old Dec 17, 2006 | 02:24 PM
502builder's Avatar
502builder
ttttttttttttttttttttttttt
Old Dec 17, 2006 | 03:43 PM
afreemanmd's Avatar
afreemanmd
I'd prolly take it to a shop for that one :/
But if i had to guess:
It would seem to be a computer glitch somewhere or a problem with the trans... The engine shouldn't care whether the truck is in reverse or not, because it does the same thing (ie increase rpm's) so unless the trans is messed up and bogging the engine down when it shifts into reverse, I would prolly guess its a comp glitch that is telling the engine to do stall. But thats just a guess.
Sorry I cant help you any more that that
Isaac
Old Dec 13, 2008 | 07:00 PM
propaneman's Avatar
propaneman
Today My X did this exact thing twice. It's never done it before. (Mine is a 02 psd). Within the last 2 weeks, the weather changed dramatically. The temp dropped from 40f to 0f! Lots of snow, cold temps..... maybe a cause???
Old Dec 13, 2008 | 08:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Check your trans fluid. Low fluid can cause the torque converter clutch to drift on and that will stall the engine. It will happen first in reverse because reverse has a higher pressure demand.
Old Dec 13, 2008 | 10:48 PM
502builder's Avatar
502builder
Pull the pan and check the filter. A ford tech had replied to one of my post about this problem saying he's seen this happen several times saying the filter falls down into the pan. I pulled my pan and sure enough my filter had fallen down out of the transmission. It's a poor design the filter is only held up by the oring on the filter neck no bolt like a chevrolet.
GabezF250
50
May 2, 2025 02:33 PM
jspringator
Jan 13, 2016 07:27 PM
gpeck
Mar 4, 2015 06:23 PM
davidmolina
Jul 30, 2014 10:19 PM
Rynopwr
Feb 24, 2012 12:08 AM
