Hot Rod Mag article
They used Edelbrock aluminum heads (of course. Edelbrock is a big advertiser with magazines like Hot Rod.) They implied that trying to secure Oz closed chamber heads was hard to do, but that's a rationalization for buying $2000 of Edelbrock heads. Wimps.
234^ duration/.610" lift roller cam. They didn't cite the LSA. Oddly, the heads have a max lift of .600".
You can whack $1000 off the price by using Oz heads, and probably pick up torque, too. Iron heads absorb less heat, so the combustion should burn more quickly. And it should run cooler with iron heads.
I agree, let's see another budget build with a roller cam. Tune it for peak torque at a lower engine speed.
On paper (desk top dyno) I'm making 435hp and 510 torque with worked over 2V heads and a performer. A little smaller Crane roller. While this may be optimistic I think using CHI heads you could easily make over 500fp of torque with good idle without the trouble of stroking.
Personally I've seen enough high torque builds for the 400 engine. I'm still waiting for just one article that makes some serious HP on a budget. The 400 engine built for the '06 EMC was a 425ci, 4.060 x 4.1 stroke with CHI 3V heads and it made 618HP. It was put together by a handful of amateurs. Had it been built by BES, the 1st place team, I have no doubt it would have been in the 700HP range.
I have not seen the article but I can imagine they tried to use as many advertisers parts as they could.
actually it is pretty simple and informative and suggests alot of waht is recommended on here
Just remember, those Chevy guys get real nervous when they hear the word "Cleveland", and that's gotta' count for something!.
https://www.ford-trucks.com/lc/lc.ph...400_power.html
No such thing as an 400M.
Under "will it fit" they said the motor mounts are the same as the 460,,,not.
Australian 302C heads are easy to find.
Something should have been mentioned about what 400 blocks to avoid.
Nothing about oiling system mods.
The performer intake was basically a rev limiter and required a 2" spacer for best power. The new 351C air-gap with intake spacers would have been a much better choice.
No such thing as forged pistons or rods? Hello? Even if you didn't know about the TMI pistons, 351C pistons will work with minor mods. The factory rods are forged steel. What's the point of mentioning way-too-expensive forged pistons if you end up using hypereutectics?
Why narrow SBC 2.1, 6.3 rods? Just have the journals ground wider when they are offset.
What's wrong with using 240 Ford rods? They're 0.5 longer at almost 6.8"and don't require the tall 1.84CH of a 340 piston. A stroker crank should use longer than stock rods and shorter pistons. This guy's going backwards.
They said the 400 piston was heavy but it was probably lighter than the 340 since it's shorter, 1.647 vs 1.84 and uses a smaller pin, .975 vs .984.
The short rod required grinding .495 off the counterweights and it created a lot of balancing problems. To reduce some of the expensive mallory metal required they used a late 302 50oz H-balancer that didn't fit right. It required spacing the fan, alternator and P/S pump to make the belt pulleys line up. It would have made more sense to trim the balancer instead.
They said a flat tappet cam should be nitrided. Huh?
Anyway, it's additional $125 cost was used to justify a custom hydraulic roller. If they knew anything about the Edelbrock's I/E flow ratio they should know a split duration cam would have been a better choice. The 1.7 Chevy rockers also threw off the valvetrain geometry. We've known about that for years.
They used a $5 oil pump shaft. Are you kidding me? I only use these in stock applications. A chrome-moly shaft is only $15-20.
The 340 pistons are for inline valve heads. They required cutting valve notches for clearance despite the piston being .030 in the hole. Which reminds me, the Edelbrock head has a beautiful Yates inspired quench combustion chamber but was totally wasted because of the excessive .070 piston to head clearance.
Modify this to make that fit, then modify that to make this fit, and again, and over, and again, and o....well you get my point.
I think I'll title this article, 1 step forward, 2 steps back.
Would anyone be willing to contact the guys who built this combo?
His name is Ken Troutman
616/583-9700
http://www.k1technologies.com
You could flesh out your post and send it in to the magazine as an editorial piece or question. Maybe get some help from some of the guys here. Give sources etc etc. Come back and post your letter here and we can take bets on whether it will get published. I would give pretty good odds that it won't tho.
Cheby guys are never wrong...
RPM___HP___TQ
3800__405__559
4000__428__563
4200__451__565
4400__470__561
4600__428__550
4800__493__540
5000__500__525
5200__502__507
5400__504__490
5600__502__470
5800__492__446
Peak HP 505@5300
Peak TQ 565@4300
What killed it for me was how low the rod:stroke ratio ended up being - 1.5:1! Personally, I would have much rather sacrificed the extra cubes for a realistic rod ratio instead of running the minimum generally acceptable level. Also, a high performance entity that whines about smog chambers, then in the same article proceeds to roll .070 thou quench with big-money, state-of-the-art cylinder heads is really missing the point.
But, like Brian S. said, it makes impressive power.
