1978 - 1996 Big Bronco
Transfer Case ID
Old Dec 14, 2006 | 12:38 PM
oldbluebronco's Avatar
oldbluebronco
Exclamation Transfer Case ID
I recently picked up a manual transfer case to swap out my automatic one but it has no tag. how can I ID it to buy the rebuild kit? i know it is a BW1356 but the wesite asks about splines.
Old Dec 15, 2006 | 09:52 AM
jem270's Avatar
jem270
I have a link with a lot of info about the 1356 I can give you but I can't seem to post it here. Send me an IM and I will give it to you.
Old Dec 16, 2006 | 10:58 PM
justshootme84's Avatar
justshootme84
If you know the year model of the t-case, that may enough to determine what parts to get for it. Somewhere around 91/92, were some changes made including possibly the output shaft spline count. Also a difference in t-cases from a pick-up vs. a Bronco in rear yoke style (slip yoke vs fixed yoke/flange). you can find some general info at truckpulls.com. I think my 88 T-xcse has the ID numbers stamped in the back housing, might look there or on the tailhousing. JSM84
Old Dec 18, 2006 | 12:26 PM
oldbluebronco
thank for your help. i emailed the guy on ebay about the rebuild kit asking about the tooth count he said the only way to know how many teeth you have is to tear it down and count them. thanks again
Old Dec 18, 2006 | 04:06 PM
justshootme84
That's probably the best way, since there's so many different versions from 87-96. I was searching e-bay earlier, and found a vendor selling rebuilt B-W 13-56 t-cases for $650 shipped in the U.S. I am looking just for a rear tailshaft housing and output shaft for a Bronco, so I can convert my 88 pick-up t-case to the shorter, fixxed yoke. If you need any more t-case help, just holler!!! JSM84
whiskeyrichard
Mar 5, 2022 10:34 AM
whiskeyrichard
21
May 6, 2009 10:14 PM
Kenny
Nov 30, 2007 12:22 AM
TFR
Jan 25, 2005 12:39 PM
Rob
Offroad & 4x4
Jan 28, 2000 06:47 AM
