divorced transfer case
Old Oct 5, 2000 | 11:34 PM
Kenny's Avatar
Kenny
Old Oct 6, 2000 | 05:43 PM
billyb's Avatar
billyb
after reading kenny's post about divorced transfer case in his truck, i got to thinking !
i have t18 two wheel drive tranny, can i get two speed divorced transfer case out of later 4wd to use in my 88f150? if possible, what years and models? what do you guy's think?? thanks for any replies.
Old Oct 6, 2000 | 11:08 PM
PAUL_2's Avatar
PAUL_2
Its my understanding that the divorced transfer cases were only used from 59 to 64 . So if you want one , you ll have to go way back & then Im not 100% sure you could rig it all up to work in an 88 truck ?
Old Oct 6, 2000 | 11:54 PM
JMR's Avatar
JMR
You'll be able to find divorced transfer cases into the early 70's, 73 I think but maybe even newer. You can probably make it work.but I think you'll have to make a cross-member to bolt it to.Maybe get the cross member that the donor t-case is bolted to and lengthen it to fit the newer (wider) frame.
John
Old Oct 7, 2000 | 07:44 AM
billyb's Avatar
billyb
paul and jwr, thanks for replies. i will look at costs of divorced case vs. the cost of converting t18( about 400.00 just for parts). then add labor!.
Old Nov 30, 2007 | 12:22 AM
ford4btrorwrse's Avatar
ford4btrorwrse
Last devorced case I know of was in a 76 available in both 1/2 and 3/4 ton conversion will require fab of case mount and 3 new drive shafts
