Powersteering PUMP
Old Dec 13, 2006 | 08:44 PM
HUNTER10's Avatar
HUNTER10
Powersteering PUMP
I think my powersteering pump is about to bite the bucket. It makes a horrible whinning noise when turning, and the brakes are crap. That being said - I'm going to go ahead and put a new one on.
First off - where is the best place to buy one and about how much $ should it cost?
Secondly, is this hard to install? I have moderate mechanic skills - should I try it myself or have the stealership do it? Is there any links on doing this yourself?
As always fellas, thanks for the help
Old Dec 13, 2006 | 08:54 PM
sgrol's Avatar
sgrol
I wouldn't let the dealership do a job like that. It's a relatively easy job and if you are not up to it any decent mechanic could handle it and charge you a whole lot less than the dealer - IMO.
Old Dec 13, 2006 | 11:56 PM
BobbyDiesel71's Avatar
BobbyDiesel71
my 02 F-350's P/S pump started to fail, heard the same whining noises and I had a real hard time turning the steering wheel at times. Te truck still had some warranty left and the P/S pump was diagnosed bad and replaced under warranty.
truck had 100K miles
Old Dec 14, 2006 | 12:51 AM
TNT in Round Rock's Avatar
TNT in Round Rock
mine just got replaced by me. it was getting HARD to steer .. brakes were still okay.
Now mine was a lot easier because I was doing the water pump at the same time so the fan and shroud were taken out.
but you will need a gear/pulley puller to pull the old pulley off and press it back on your new pump. But after that .. 3 bolts on the front that hold it in it's housing. You have 2 return lines - one top and one bottom that release with pliers - clamp bracket.
your high pressure is one line on the side facing the tire.
Also, remember when you pull that bottom line off, have a bucket ready it will drain.
hope this helps
Old Dec 14, 2006 | 06:23 AM
ponch37300's Avatar
ponch37300
If you don't have the pulley puller you can get one at most autoparts stores. You leave a deposite and get your money back when you return it. Free tool usage.
Old Dec 14, 2006 | 01:46 PM
ramsmoker's Avatar
ramsmoker
Talking Pump
I can't think of the name right now but you can Goggle these guys. I have a very weak pumo and $250.00 they have a super pump they say will turn under any condition, mud, large tires. I don't remember the price of the other route which is a Saginaw pump with remote mount resevoure and custom bracket to direct bolt to a PSD truck.
Old Dec 14, 2006 | 02:43 PM
WMRiceman's Avatar
WMRiceman
I changed my P/S pump yesterday. Autozone had the pump for $42.00 and has a life time warranty. Pulley removal and installation tool is a must, can't do it without it. Took me 3 hours and I flushed and filled with synthetic ATF.
Old Dec 14, 2006 | 02:46 PM
sgrol's Avatar
sgrol
Mark, what were your steering symptoms/problems and the results of the new pump so far?
Old Dec 14, 2006 | 02:50 PM
cgl's Avatar
cgl
It's made by AGR Peformance. It is called the Ford Super Pump here's a link to it http://www.agrperformance.com/produc...Ford&model=136
I'm gonna go this route should mine ever fail.
Old Dec 14, 2006 | 02:58 PM
WMRiceman's Avatar
WMRiceman
Symptom was noise like a bearing going bad, steering hard to turn and spongy brake pedal. Now with a new pump, all is good, quiet pump and I have brakes and steering at the same time.
Old Dec 14, 2006 | 08:15 PM
Uzumati's Avatar
Uzumati
AutoZone has the AGR for 226.99 - special order
http://autozone.com/servlet/UiBroker...00%7C%7E867257
Old Dec 14, 2006 | 10:23 PM
John7894's Avatar
John7894
Everyone, Here's the link to Alan's original post where this pump was discussed.
https://www.ford-trucks.com/forums/5...k-ps-pump.html
FWIW, Most of my hard steering issues went away with the purchase of a new set of tires. I replaced those damn load range C's that came on it with some load range E's. Higher pressure = less resistance = easier steering.
NWO_diesel_nut
May 23, 2011 11:02 AM
Kodiak450
Mar 15, 2011 07:23 PM
powerstroker100
Dec 18, 2010 06:10 PM
kupiec20
Nov 6, 2008 07:53 PM
