No pumps
Old Dec 13, 2006 | 08:43 PM
nova801428's Avatar
nova801428
No pumps
When I turn my key on, on my 86 ranger with a 2.9L V6, my pumps do not kick on for three seconds as they should. I have power at my fuel pump relay when my key is on, and when I ground a certain wire from the fuel pump relay, it stays on and does not shut off until I remove the ground. Any help? Thanks
Old Dec 14, 2006 | 06:33 PM
nova801428's Avatar
nova801428
how come the pumps stay on continuously when I ground the coming out of the fuel pump relay?
Old Dec 15, 2006 | 06:00 PM
87 XLT's Avatar
87 XLT
See if you can pull the codes.
Looks like the computer/ECM isnt grounding the tan/green stripe wire from the pump relay as it should.
If the ECM is dead/not grounded/not receiving voltage you wont be able to pull the codes.
So take a couple of minutes to see if you can pull codes and post back.
Old Dec 15, 2006 | 07:00 PM
nova801428's Avatar
nova801428
I have tried to pull the codes once and was unsuccessful. Can you please tell me what I need to pull the codes?
Old Dec 15, 2006 | 08:59 PM
87 XLT's Avatar
87 XLT
Code scanners are dirt cheap. I have a 30 buck Actron CP9015 that I use on my Fords.
Old Dec 15, 2006 | 10:42 PM
nova801428's Avatar
nova801428
well, I have no check engine light, and I was using an analog volt meter. I have to do it a certain way though. I am going to bet money it's the eec thats been causing me trouble, because, it should ground the relay, and make it shut off and on for 3 seconds, does that sound right? I have checked almost every possible wire that comes off of the fuel pump relay and can't find any damaged or disconnected wires. This all leads me to believe that my eec is shot, unless a sensor is causing my fuel pumps not to come on at all. But, when I make my pumps come on and try to start my truck (I have spark) I can't get my truck to start. What could possibly cause this, maybe a bad eec? or two of them?
Old Dec 16, 2006 | 02:24 AM
87 XLT's Avatar
87 XLT
Looks like theres 2 things the ECM is not doing, it's not grounding the pump relay & not pulsing a ground to fire the injectors.
The ECM is toast or it's not receiving power from the EEC main relay or it isnt grounded.
The factory wiring diagram for my 87 2.9 shows voltage from the EEC main relay to the ECM is on 2 solid red wires.
Pull the connector off of the ECM, turn the key on & see if you have 12 volts on those red wires.
On my 87 the ECM ground wire splices into the negative battery cable near the battery.
If you have voltage on the 2 red wires & a ground on black/light green then it looks like the ECM is shot.
BTW, my 87 is not equipped with a check engine light, are you sure your 86 has one?
Edit, i'm guessing your 86 is wired the same as my 87.
Have you got a decent set of wiring diagrams for your 86 so you can double check the color coding of the wires?
Old Dec 16, 2006 | 10:39 PM
nova801428's Avatar
nova801428
I do have a wiring diagram but all of the wire colors are off, but I know where all the fuel pump relay wires go. I ripped all of the wire bundles apart so I could check the wires to make sure they were all right and they are fine. I know my 86 does not have a CEL, did I say that my truck did, if I did it was not intensionally. I am pretty sure my eec is shot, I will go check my grounds and do all of the things you said. What should I do next once I did all of the things you said and they were allright?
