Overhead DVD
Old Dec 26, 2006 | 10:02 PM
ptolalibertad's Avatar
ptolalibertad
where did u guys mount your dvd player and all the wires?
i put mine under the passenger seat...along with the fm transmitter and 5 miles of wires and cables...power came from the cigarette lighter in the center consol and i put a power switch there to turn off and on.
Old Dec 30, 2006 | 10:11 PM
3KIDDAD's Avatar
3KIDDAD
Mission acomplished... My install went well. I basically just drilled and tapped 4 holes in the metal plate of the seat then just screwed in the monitor mounting bracket with the supplied hardware. I'd say the headrests were the easiest part of the install. I mounted the dvd player inside the center counsel. You can see a picture in my gallery I plan to post more pictures tomorrow. Thanks everybody especially l8rg8r.
Old Dec 31, 2006 | 10:17 AM
azmeeks's Avatar
azmeeks
Headrest Monitor
I went with headrest mount. One problem I have is the control box the monitor connects to does not fix completely under seat. There is no room under the seats, any sugestions? It is currently under seat but hangs out some and I am scared kids may kick it and damage it on accident.
Old Dec 31, 2006 | 11:39 AM
3KIDDAD's Avatar
3KIDDAD
Checkout my gallery... I installed mine vertical in the center counsole... It came out very nice and works well with easy access. Very nice system considering I only paid $300 at Fry's. I did have to install a ground loop isolator from Radio Shack to eliminate a bit of hum in the audio. The remote sensor is mounted down near the rear seat controls.
Old Dec 31, 2006 | 12:48 PM
ptolalibertad
my dvd unit sticks out a little so the middle seat passengers can access it easily. in one year i have had no problems other than the occasional person turning off the unit mid movie with their foot. i also put under the middle seats a 12oow power inverter and the gamecube system. the game cube is not mounted, when the want to play the pull it out.
Old Jan 5, 2007 | 01:35 PM
sunshine4boys's Avatar
sunshine4boys
I have an '03 Expedition. Factory DVD is fine, except headphones are wired, and only good for 2 headphones (I have 4 kids, so that doesn't cut it). Looking to install monitors in 2nd row headrests (so boys in 3rd seat have their own DVD). Anybody ever done this? Thanks.
Old Jan 5, 2007 | 02:02 PM
L8RG8R's Avatar
L8RG8R
WAY TO GO 3KIDDAD!! Looks great!
FWIW, I put my video control boxes under the rear cup holders in the back of the center console. There is a ton of room in there.
As far as the player itself, mine is in-dash. For a stand alone player, probably under the second row bench is going to b e the best bet.
Old Jan 5, 2007 | 02:16 PM
L8RG8R's Avatar
L8RG8R
My truck has the bench seat for the second row and the headrests are so small. I don't know any monitors that will fit. However, it may be possible to mount them directly in the seat back. Of course this wouldn't be a good idea if you ever lay the seats flat to haul stuff as the screens may get smushed.
Old Jan 5, 2007 | 02:28 PM
sunshine4boys
another thought
what about changing out the dvd to a wireless one? how hard is that (and is it expensive?) Thanks.
Old Jan 5, 2007 | 02:31 PM
L8RG8R's Avatar
L8RG8R
I don't know much about those. Anyone?
Blurry94
2004 - 2008 F150
Feb 13, 2017 04:26 PM
geekjon
Crossovers
Feb 10, 2017 05:34 PM
KKYoung
Feb 2, 2016 07:04 PM
waypoint
Dec 16, 2007 02:00 PM
