door ajar light and beep
Old May 24, 2006 | 10:16 AM
3.0 Ranger's Avatar
3.0 Ranger
my ranger is a 2003 and i am having problem with the door ajar light and the beep that follows it. whenever i open my passenger door and close it again the light flashes and beeps and will not stop for about 10 minutes even though both doors are completely shut. the cab overhead light also stays on while this happens. is this an electrical problem? how can i fix this?
Old May 24, 2006 | 06:42 PM
john112deere's Avatar
john112deere
The switch in the door, which is part of the latch mechanism, tends to be troublesome. A lot of people, me included, have had good luck spraying WD-40 on the latch to lubricate the switch. It's cheap and easy, so give it a shot (pun, such as it is, intended).
Old May 25, 2006 | 01:03 AM
natebaker's Avatar
natebaker
It's very common. It happens to me all the time. I spray some WD-40 and it works well for a while.
Old May 25, 2006 | 08:15 PM
73effie's Avatar
73effie
This has also been an issue with every Ford I have ever owned. Just wanted to confirm that the WD-40 trick works.
eddie-
Old May 25, 2006 | 11:18 PM
Ar-plud6's Avatar
Ar-plud6
Yeah i had the same thing with my 98 ranger i used some Howes Firearm lube spray(heavy duty) and havent had a problem ever again.
bothersome
Feb 7, 2020 02:31 PM
sbappleg8
15
Aug 2, 2017 11:45 AM
terans
Aug 24, 2015 04:15 AM
Motsiball
Feb 10, 2015 04:46 PM
00Explorer
Electrical Systems/Wiring
Sep 24, 2013 03:02 PM
