Hey all, its starting to get a little colder here(about 25-30 at night) and my truck is acting extremly cold natured. its a 90 f250 with the 351. i can go and start it and let it idle for at least 10 min before it will move, before then it will die when i give it gas. any ideals? i was thinking maybe o2 sensor.
well i ran a scan and came up with an egr, speed sensor and heated exhaust gas not switching(running too lean) i unhooked the battery and done another scan and came up with no egr code and exhaust running too rich. i might pull the iac off tomorow and clean it.
I have a 96 F150 with 5.0 V-8. Well, I had 5 engine codes for O2 sensors, the headers I have, I have to custom tap holes to put the sensors in, makes the truck run lean without the sensors, but I don't have trouble with cold idling or problems with it cutting out. I'm sure the Idle Air control is your problem with your F250/351 V-8
I just fixed this on my truck (Last friday). It is the IAC. This will keep it running.
Also another thing I had to/did fix is: there is a tube, about 3/4 inch in diameter, and it hits your exhaust before the two expansion chambers ( that might be my truck, its roughly right under the passenger seat.) If this is broken it might cause it to run a little rough as well. There is a fix kit for it, its basically a heat resistant flex tube.
i did a tune up about 5000 miles ago. i just cleaned the iac so i will see in the morning if it helped. it is idleing better and the exhaust doesst smell as much like gas
air cleaners good, the plugs only have about 1500 to 2000 miles on them, i didn't have enough cash when i did a tune up a while back. i think the iac might have helped,but can't be sure until tomorow. this cold weather problem is really the only thing i need to fix.
