F2#&!n' Mouse!
Old Dec 12, 2006 | 08:58 AM
BDISCO's Avatar
BDISCO
F2#&!n' Mouse!
Found a good size nest on top of the engine plenum. Fuel seemed to be spraying out of an over flow tube(passenger side)? Dripped all over my new driveway. Could the little critter have blocked something and caused this to happen?
Old Dec 12, 2006 | 09:27 AM
Pocket's Avatar
Pocket
No, a mouse could not have fit anything up that tube. That is the fuel bowl drain valve that is leaking. With the recent switch to Ultra Low Sulfur Diesel (ULSD), there have been masses of PSD owners who have had fuel leaks in the exact same spot. The o-rings are shrinking with the introduction of the new fuel, and causing the leak. Look to the left at the sponsors, DFuser sells the o-ring kit to repair it.
As far as critters in the engine bay, it happens. I once found a bee hive that tried to make the stock airbox their home. That didn't last long.
Old Dec 12, 2006 | 03:16 PM
BDISCO's Avatar
BDISCO
Could the o-rings have just gone bad because of age? Truck is a 2000 but only 55k on the odm. How much $ approx to have stealer do this service?
Old Dec 12, 2006 | 03:40 PM
ryaneverk2's Avatar
ryaneverk2
Not sure what the dealer will charge, but you can do it yourself most likely. The o-rings are cheap, and it's just a few screws holding the valve in place. If you look through the recent threads, you're bound to find a few going over how to replace the o-rings. Like Pocket said, it's been a real common problem, lately.
Old Dec 12, 2006 | 05:29 PM
mxfam4x4's Avatar
mxfam4x4
Thumbs up
:-x25 Just Did This Repair On My 99' No Big Deal To Do It Yourself!!!
I Believe The Stealership Has Charged As Much As $200.00 U.s. To Do The Repair You Can Do Yourself For Under $20.. And About A Half An Hours Worth Of Labor. 4 Torx Screws On Valve, Replace O Rings, Reinstall Torx But Don't Over Torque, Reconnect Drain Hose, Reinstall Filter Cover And Yopur Done.
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Are you sure that the mouse didn't have a T20 Torx socket in it's pocket? He may have loosened the bolts on the back of the valve, causing it to leak.
Old Dec 12, 2006 | 06:39 PM
YellerMax's Avatar
YellerMax
The stealership will charge you $60 labor to replace the o-rings and $270 labor and parts to replace your muffler bearing
Old Dec 12, 2006 | 06:51 PM
Uzumati's Avatar
Uzumati
but they will top off your blinker fluid for $35.00
Old Dec 12, 2006 | 07:02 PM
YellerMax's Avatar
YellerMax
I had a $35 copay on my prostate exam last time I went to the dentist too... seems high to me
Old Dec 12, 2006 | 07:08 PM
PowerstrokeJunkie
Did he find a TV remote too?
YellerMax's Avatar
YellerMax
lost me there
Old Dec 12, 2006 | 07:11 PM
PowerstrokeJunkie
Ah, it's a larry the cable guy joke-
"Went to the doctor for a prostate check the other day, he said he found something. I was like "found something?"... i didnt even know you were lookin' for anything... i sure hope it's the TV remote cause every time i fart the volume goes up on the television.... Thats the worst dentist i've been to in a long time"
Old Dec 12, 2006 | 07:15 PM
Uzumati's Avatar
Uzumati
This one went south in a hurry.
Old Dec 12, 2006 | 10:58 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Git er done, and do the O-rings yourself. Only the most inept wrench turner cannot do this project with the help available here.
Old Dec 13, 2006 | 06:39 AM
YellerMax's Avatar
YellerMax
Unless you have back problems--this one can be a lumbar buster. Then again, if you have back problems you should avoid car work in general
