Ignition Key Problems
Old Dec 17, 2006 | 03:48 AM
89MustangGX's Avatar
89MustangGX
I took things apart today, found the lower part of the actuator rod was broken and seemed to have jammed up the works. Good news is that I cut off the end of the new actuator and slipped it in and I believe it will work.
Bad news is that it wasn't until I had most of the tilt apart that I gave up and decided to short cut it (by cutting the piece). Bad because I wasted a whole day trying to figure the thing out rather than taking the easy way, and also because I seem to have broken the shift indicator wire plastic cover. Hoping I can superglue it and still leave the wire inside free to move - otherwise I'll be looking for one.
Oh, BTW, also tried to fix my blinkers by changing just the cam rather than the whole $100 piece -- no good. On top of that, as I found out 3 hours of troubleshooting later, the contact wires on the cheap replacement piece I bought were too long and making my blinker and brake lights do funny things.
So, all in all, truck should start now (when I finish getting it together), changed bulb in dash, broke shift indicator, blinkers still will not hold in position. I think I'm ahead -- slightly.
Anyway, thanks for your help -- couldn't have done it without you. And if it doesn't work -- I'll be back!
Adam
Old Jan 12, 2007 | 09:40 AM
Lumpy87's Avatar
Lumpy87
I have an 87' f-150 and the exact same thing happened to me yesterday. I turn the key to RUN and I get lights and accessories, but when I turn to START nothing happens and the key doesn't return to the RUN position. I haven't tried jumping the solenoid but I'm confident it will start that way.
My truck, however, has a manual transmission does this mean I don't have an automatic column? It's tilt and under the speedo is the gear indicator which has nothing to indicate.
If I don't have an automatic column then am I SOL getting parts to fix it Catfish?
Loosmaster. The diagram you posted is pretty tiny. Where can I get that diagram?
Well, I just went out and tried to start it by jumping the solenoid and no luck. It would turn over but no start. It's only 4° outside but it usually starts ok in this kind of weather. After looking at the outside of my steering column and I'm starting to think I'm just going to have blow a wad of money for a tow and a mechanic.
This will be the second time getting this fixed and I suspect there must be a flourishing business in makingand selling these parts even crappier than the original crappy part.
Old Mar 1, 2007 | 01:11 PM
LoosMaster's Avatar
LoosMaster
Sorry for not getting back sooner. Was indisposed for a bit. Hope this works.
Old Mar 1, 2007 | 03:46 PM
Lumpy87's Avatar
Lumpy87
I got mine fixed like I said. Had it towed and got the signal switch change as well.
After it was already in the shop I came across this thread with some really good pictures of my problem.
https://www.ford-trucks.com/forums/5...ch-thread.html
banshee_man_96
Nov 22, 2018 07:20 AM
AteThePrincess
1983 - 2012 Ranger & B-Series
Apr 24, 2016 03:16 PM
fastcat1977
22
Jan 30, 2016 09:04 PM
Liza Phillips Gay
Mar 7, 2015 06:44 PM
steeldust
Electrical Systems/Wiring
May 4, 2004 04:50 PM
