Aftermarket Products
Sponsored by: Worksport
Adding winter bed weight
Old Dec 11, 2006 | 11:27 AM
beej1024's Avatar
beej1024
Anyone ever used a product called ShurTrax? Looks like a baffle you fill and put in your bed. Thinking of picking one up.
Here is the product: ShurTrax baffle
Old Dec 11, 2006 | 04:38 PM
F250_'s Avatar
F250_
Couple of bags of sand would be good, too, as long as you can minimize moisture infiltration so you can also use it on ice of required.
Old Dec 11, 2006 | 05:28 PM
beej1024's Avatar
beej1024
I've done the sand bags, cement, and some other junk and always been ticked in the spring when it's time to unload it. This looks like a neat idea, wonder if the moisture trapped below the thing would be an issue. My truck has a LineX liner in it now.
Old Dec 11, 2006 | 05:35 PM
CobraXP's Avatar
CobraXP
I always buy (4) 60lb sand bags the shape of tubes from Lowes. Seems like they are $3.00 a bag. I put them in the bed against the cab. Never had a problem with them breaking, etc, as they have a plastic bag lining in them also. In the spring, I use the sand to help level any spots in the yard...
Old Dec 11, 2006 | 10:23 PM
DiscountPowerPrt's Avatar
DiscountPowerPrt
I've seen that product you are talking about. Looks pretty cool. Easy to unload
Old Dec 17, 2006 | 11:56 AM
i1dery's Avatar
i1dery
Thats looks like the best way to go, with the bladder easy and simple.
Myself i get the free service from the state a dumptruck of sand and a
pallet of gunnysacks for sand bags. flood zone area
Old Dec 31, 2006 | 07:29 AM
ckal704's Avatar
ckal704
I use tube sand. it makes a big difference with the heavy PSD over the front wheels and only the short bed over the back wheels.
I think I'd rather see bedside containers of high impact plastic that go over the wheel wells and extend rearward to the tailgate. Sort of like some toolboxes I've seen. I think those would be the cat's meow because they'd be out of the way of material being slid into and out of the bed. They'd also keep the sand perfectly dry.
Old Dec 31, 2006 | 12:04 PM
Ferguson65's Avatar
Ferguson65
I like the idea of it and have really given some thought to picking one up. Seems like a better idea than the couple 85 pound block i usually throw in.
Old Jan 7, 2007 | 03:43 PM
Bocomo's Avatar
Bocomo
I made a small 2x4 frame to fit around the wheel wells, then I put bags of sand inside the frame. Kept the weight over the wheels where I wanted it and kept them from sliding.
I do like the idea of the bladder though. Seems easy, clean and should certainly do the job.
Bocomo
Old Jan 7, 2007 | 05:51 PM
Zip's Avatar
Zip
I used snow this winter. Not because I wanted to but because we had so much of the stuff. The box was almost full only a couple inches below the lip. It warmed up for awhile so I shoveled it out and boy was it heavy.
Old Jan 10, 2007 | 10:01 AM
RealTruckMan's Avatar
RealTruckMan
FTE Sponsor
Shurtrax All Weather Water Filled Traction System is a great alternative to dangerous concrete blocks and messy sand tubes.
Check it out!
http://www.realtruck.com/productline/924/5535/1/shurtrax_all_weather_water_filled_traction_system. html
Old Jan 12, 2007 | 06:57 PM
smokestone52's Avatar
smokestone52
Course I live in Las Vegas, so weight in the winter is something I usually put on my belly! Now back on point. I did do concrete blocks. I do not know how they are dangerous. Just brace said blocks so they don't shift around. I just don't see any sense in spending money on bed weight. Heck lay down some plastic and shovel in some sand. Fer crying out loud these are pick-up trucks. Geez pleeze, don't scratch your beds.
Oh just case your wondering, I spend my winters in Idaho, Montana, skiing. So I know a bit about traction. I was born and raised in central Idaho, which right now has about 4 feet of snow on the flat. Been there, done that.
Old Jan 13, 2007 | 02:08 AM
sean1997's Avatar
sean1997
I have a ShurTrax and actually got to use it this week. It was very easy to setup, less than 10 minutes total. I bought some ratcheting tie down straps to hold it in place. I live in Seattle and we have lots of hills here so I thought I needed some extra weight in the back and this seamed to work well. One note on the setup, even though my driveway is relatively flat for the Seattle area, the little bit of slope did cause the water run to the downhill side of the ShurTrax. So I end up parking the truck with the back of the bed downhill until the water froze so that more of the weight was located further back in the bed. So far I like it and it even fits behind the rear seat of my crew cab when not in use. Try that with concrete or sand.
-Sean
Old Jan 13, 2007 | 12:36 PM
fyre82's Avatar
fyre82
Ideally any traction weight should be either over the rear axle or between the axle and the cab. This distributes the weight more evenly over the frame and keeps from "unweighting" the front end. This is the same principle that truckers use on not fully loaded flat beds or heavy loads, etc.
Where I live there is lots of black ice and heavy frost on the highways in the winter in addition to packed snow and ice and I have found that technique works well with a simple hub lock for more steering traction when the pavement is not slick enough for 4x4 but slick enough to send your vehicle off the road with the slightest false move.
Old May 30, 2007 | 12:35 PM
lund's Avatar
lund
I have one, it works great. Fill it up in the fall, no fuss no muss. In the spring, syphon out the water and youre good to go. Be sure to bungee it in, because it will slide around. Mine sits on the Line X bed linner
nitro3421
6.7L Power Stroke Diesel
28
Jan 2, 2015 05:54 PM
edawgm
17
Apr 6, 2013 04:55 PM
Apocalypse
Mar 27, 2013 03:28 PM
jdadamsjr
55
May 17, 2012 09:45 AM
Dr. T
22
Aug 25, 2011 04:57 PM
