Boost Fooler resistor?
Old Dec 10, 2006 | 02:18 PM
John311t's Avatar
John311t
So after i put my chip back in after a reburn, i go for a run and i hit 28 psi and then i got defueled. I was talking to someone and they said you can put a resistor in the MAP circuit to fool the pcm instead of the one that goes in MAP sensor line from the intake? As anyone else heard about this, it makes sence but i have never heard of it before.
Old Dec 10, 2006 | 03:50 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It's a 4.7 volt zener diode. Install it in the center wire in the map sensor harness (green/black trace). Everything over 4.7v is shunted to ground, so no matter how much bost you make the map only reads slightly less than it's maximum.
It's far less expensive than any other means of controlling the SES light, but it seems to lag a bit, especially when ambient temps are way down, so you might still get an occasional flicker from the SES.
Old Dec 10, 2006 | 06:24 PM
John311t's Avatar
John311t
Do you use this diode? Its sounds alot cheaper than the ones that go in line to the map sensor so i will probably go that route.
Old Dec 10, 2006 | 07:51 PM
Lushman's Avatar
Lushman
Are you trying to avoid installing a boost regulator like the one here: http://www.itpdiesel.com/store.php?c...on=show_detail
It is not that expensive and should solve your issue!
Old Dec 10, 2006 | 07:53 PM
DavidT.'s Avatar
DavidT.
John, I'm using the SPDiesel overboost eliminator. It's only $29.99 on their site, www.spdiesel.com and go to the new products page. It's a lot cheaper than the other inline MAP foolers and it works great, plus it saved me a lot of time hunting my not so large town for the right diode to make one myself. And if I did make one myself it wouldn't be this nice with plug'n play connectors and nicely covered wires. I haven't set an SES light for overboost since the installation of the overboost eliminator. Just some food for thought
Old Dec 10, 2006 | 08:29 PM
Lushman's Avatar
Lushman
That seems a little drastic as they want you to disable The fuse!?!?! Maybe I am mistaken???? It even talks about the competitors in case you have the 10K/18K mod or other mods which are better?? All you are trying to do is keep the CPU from seeing more than 24PSI! As long as my chip/CPU doesn't see more than about 25psi of boost, I don't see the SES code anymore.
Old Dec 10, 2006 | 09:49 PM
John311t's Avatar
John311t
My buddy can get pretty much anything electronic so finding the actual electrical part wont be hard. Whats this about losing low end power though?
Old Dec 10, 2006 | 10:13 PM
cookie88's Avatar
cookie88
FTE Emeritus
I used to. It worked perfectly with limited mods, but the harder I pushed it the more often I would get that annoyng little flicker of the SES. From there I switched to a pop off valve, but it wasn't worth a hill of beans in the cold....didn't work at all. From there I switched to a mini regulator and that was the last time I ever saw an SES light.
If money is an issue then the $1.07 zener dide is a no brainer.
Oh yeah, forgot to mention in the first post. The diode get one end soldered into the map sensor wire, the other end of the diode runs to ground.
Tominky
2009 - 2014 F150
Jun 10, 2017 03:51 PM
xlhr8r
Sep 9, 2015 02:41 AM
70T351W
Electrical Systems/Wiring
May 30, 2005 08:20 AM
444dieselrod
Feb 20, 2005 07:15 PM
PaulzF150
Feb 10, 2005 03:06 PM
