bent wheel stud??
Old Dec 9, 2006 | 01:11 PM
powerstroke6ltr's Avatar
powerstroke6ltr
bent wheel stud??
Took of the drum on the passenger rear and had a heck of a time pulling it off. Tried to put it back on only to find one of the wheel studs didn't line up completely so I had to really work to get the drum back on. how much do studs cost and are they hard to replace?? Should I replace them?? thanks!!
Old Dec 9, 2006 | 03:31 PM
2jhanna's Avatar
2jhanna
most studs are cheap, less than $5.00. not too hard to replace. if it is bent badly, you may want to try to straighten or cut the threaded part off. then pound the shoulder out of the flange.
the new stud can be "set" into place if you put some grease on the splines and around the hole. stack a bunch of washers on the stud and seat by tighting a lug nut to pull it in.
Old Dec 9, 2006 | 09:22 PM
powerstroke6ltr
Its bent just bad enough so that it barely lets the drum on. Do i run any kind of risk operating the truck in said condition??
Old Dec 9, 2006 | 10:57 PM
2jhanna's Avatar
2jhanna
are you able to get a lug nut on and tight ? you may be able to put a socket and long extension over the stud and lug nut and straighten it out. what is the worst case, you break it. if you can't get a good grip with the lug nut and socket, remove the lug nut and find a piece of galvanized water pipe, maybe 1/2", and slid over the stud to straighten.
i would say, if you have 8 studs, 1 broken does not cause a major problem unless you are fully loaded and on a rough road
Old Dec 10, 2006 | 12:49 AM
powerstroke6ltr
I tapped it with a 15# sledge a few times and am able to get teh drum on and off much easier. It wasn't extremely difficult, just took a pry bar... will look into a new stud...thanks for the help!!
kmacht
May 10, 2020 06:14 PM
gomer450
Sep 11, 2013 07:20 AM
Recycleking
Aerostar
15
Oct 11, 2007 10:28 PM
Deadeye1963
Jul 2, 2007 08:20 AM
schmidty_dog
1997 - 2003 F150
26
Jun 25, 2007 05:11 PM
