help!!!
Old Dec 8, 2006 | 10:35 PM
melon1's Avatar
melon1
help!!!
Just replaced the master cylinder (clutch) and slave cylinder on my 2002 ford ranger. I can not get the quick disconnect back onto the slave cylinder. I read were you could remove the little metal ring inside the slave that holds the fitting on and bend the tabs down a little and it would help. I tryed this with no luck. Any one no the trick?
Old Dec 8, 2006 | 10:44 PM
Ultramagdan's Avatar
Ultramagdan
Hello melon1 and thanks for joining.
This is the introduction forum and you have done a fine job introducing yourself. You just need to browse on down to the Ranger forum and ask your question there. There are a lot of helpful people there that can answer your question. Be sure and look over the rest of the forums as well.
Enjoy the site!
hotrodaunie
New Member Introductions
Nov 7, 2014 03:58 PM
ford ranger lover
Oct 21, 2008 09:28 AM
Rngrxlt4x4
Jan 28, 2007 09:14 PM
slats63
Nov 4, 2006 02:51 PM
