Rearend buster!!!!
Old Jan 14, 2002 | 10:38 PM
55FordLover's Avatar
55FordLover
Rearend buster!!!!
Will the original rearend be able to handle a 77 302 with 85/86 AOD combo? HELP!!!
Old Jan 14, 2002 | 10:44 PM
54Guy's Avatar
54Guy
Rearend buster!!!!
The original rearend in what?
Old Jan 15, 2002 | 08:30 AM
Caddy 53's Avatar
Caddy 53
Rearend buster!!!!
[updated:LAST EDITED ON 15-Jan-02 AT 09:32 AM (EST)] REAR BUSTER:
IF you think you have to or want to replace your rear I found a nice match from a 65.I understand that approx yr's of 59-72 matches up w/ 53-56.. 61" outside to outside,ford 9", various ratio's, Spring pad correct loc. I found a 3:10 Better than orignal 31 for hi-wy
Caddy 53
Old Jan 19, 2002 | 09:50 PM
55FordLover
Rearend buster!!!!
1955 ford f100....have that ol dana 44 rear....
Old Jan 19, 2002 | 11:37 PM
jml's Avatar
jml
Rearend buster!!!!
Old Jan 20, 2002 | 08:54 AM
truckfarmer's Avatar
truckfarmer
Post Rearend buster!!!!
the stock rearend will handle that little 302. Usually we change the rears to 9" Fords because we want better gear selections. With the AOD, you should be able to live with the 3.92 gears. Seeing the final drive of the AOD is .70:1, your 3.92's will seem like 2.79's when in overdrive.
Neppy
May 17, 2002 09:19 AM
otto
Mar 2, 2002 06:05 AM
Greywolf
Nov 11, 2001 02:27 AM
dpattonfl
Mar 25, 2001 09:42 PM
jowilker
Jul 24, 2000 07:39 AM
