9"rearend
Old May 6, 2002 | 02:42 PM
Neppy's Avatar
Neppy
9"rearend
Old May 15, 2002 | 09:15 AM
19F10059's Avatar
19F10059
9"rearend
HEY FORD NUTS this probabley sounds stupid but how do you identify a 9" never have realy seen one im new to this stuf THANKS TERRY :-X11
Old May 15, 2002 | 09:59 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
9"rearend
Here is a web site with some useful data.
http://hiqties.hypermart.net/9inch.html
9" axles have a center section that is removed from the front for easily changing the ratio by swapping the "pumpkin".
Old May 15, 2002 | 10:08 AM
mtflat's Avatar
mtflat
9"rearend
The housing around the pinion is larger due to the larger bearing support that makes the 9" so desirable. What I look for are the two bottom studs/nuts that cannot be removed by a ratchet/socket - open ended wrench needed due to the housing.
Old May 17, 2002 | 09:19 AM
51f1's Avatar
51f1
Post 9"rearend
Check out: http://www.prestage.com/cars/RearEnds.asp
http://www.ridgenet.net/~biesiade/Fordrears.html
and
http://hiqties.hypermart.net/9inch.html#top
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
