rear diff lock
Old Dec 7, 2006 | 06:01 PM
yttocs's Avatar
yttocs
rear diff lock
anyone have a rear diff lock on their truck? my 78 f100 2wd is sucking pretty hard in the snow and was wondering if anyone has some ideas.
Old Dec 7, 2006 | 06:58 PM
Mil1ion's Avatar
Mil1ion
Maybe check the drivetrain forum for drivetrain topics ?
I think LOCK is the wrong term.
Limited slip or Traction-Loc as opposed to a Locker type rear.
In the wreckers look for a truck/van with an H in the axle code (H2,H4) or L on the axle tag. (3L25)
Old Dec 7, 2006 | 09:03 PM
samickguy15's Avatar
samickguy15
You can pick up a new traction lock unit for around $200
Old Dec 8, 2006 | 03:26 PM
Mo52Merc's Avatar
Mo52Merc
Is a traction locker something that can be gotten through a local parts store or where could it be found?
Old Dec 8, 2006 | 11:25 PM
abnormloffrd's Avatar
abnormloffrd
automatic lockers and limeted slips in 2wd are scary in snow and ice becuse if one tire starts spinning the other one w/traction engages and you spin a brody w/out trying. Put better tires on and some weight to the back.
Old Dec 9, 2006 | 06:37 AM
darrin1999's Avatar
darrin1999
do you have a 9" or dana 44? i think they make an aussie locker for both, and im putting one in the front of my f250 with a d44... theyre just a little over 200 dollars and work better than a limited slip
Old Dec 10, 2006 | 05:45 AM
lucky no. 7's Avatar
lucky no. 7
boy i'd sure like to get ahold of a locker for the front in my 79 f-250 myself, its a 44, do them aussies have a website
Old Dec 10, 2006 | 06:39 AM
darrin1999's Avatar
darrin1999
www.offroadlockers.com is their website its going to be fun when i finally get my truck done... but its still probably a year away from being fully complete because of a few special things im doing to it like a 545 stroker running on propane... its also getting a spool rear and 4 wheel disc brakes, 4" full spring lift, then the last thing im getting is 17" rims and 37" tires
Old Dec 10, 2006 | 09:33 AM
snowdog79's Avatar
snowdog79
Does anyone know of a source for a limited slip conversion for a 9" rear, 3.50 gears? If so,how much $ and how hard to install?
Thanks!
Old Dec 10, 2006 | 03:12 PM
Mil1ion's Avatar
Mil1ion
True Lockers are only good for race track use.
They aren't meant for the street use.
Old Dec 10, 2006 | 08:00 PM
JBradley500's Avatar
JBradley500
i ran my truck with lockers in 2wd (front drive shaft isn't installed) the other day through the lawn with my small tires on (28's maybe) and i got stuck with 1/8 of snow on the ground and 1" of mud below. i think tires and weight are the things you should spend your money on.
ED Milk
Sep 4, 2021 07:48 PM
mdr617
Offroad & 4x4
Jan 22, 2014 11:12 AM
remhaust
6.7L Power Stroke Diesel
13
Jan 8, 2013 09:11 AM
OffroadSD
18
Sep 14, 2012 09:55 AM
Brian3676
Jan 10, 2011 05:50 PM
