head light wiring
Old Jan 28, 2002 | 06:22 PM
jaye's Avatar
jaye
head light wiring
I'm rewiring my 55 F-100 and are wondering if I should use the original head light switch or switch to another one. I've read articles about getting brighter lights and was wondering if the switch itself would make a difference in the brightness of the lights. Has anyone used any after market switches that worked better?
Thanks in advance
Jaye
Old Jan 28, 2002 | 10:18 PM
Franklin2's Avatar
Franklin2
head light wiring
The original switch would work fine, especially if you are changing to 12 volts. The original unit is fairly heavy since it is a six volt unit.
Old Jan 28, 2002 | 10:47 PM
MO51's Avatar
MO51
Post head light wiring
I went with aftermarket, and two switches later wish I hadn't. If the original works, stay with it. The "built in" (on a 51 at least) circuit breaker is superior to aftermarket fusing, in my view.
Old Jan 29, 2002 | 01:17 AM
darkhorse54's Avatar
darkhorse54
head light wiring
I'm using the 56 12 volt switch in my 54 f100 and it works great.
Old Jan 29, 2002 | 07:30 AM
barry's Avatar
barry
head light wiring
Like anything else, make sure your grounds are clean and have good connections. Nothing will dim a light's brightness than a poor ground. The headlight switch won't really make a big difference.
Old Jan 29, 2002 | 08:50 AM
truckfarmer's Avatar
truckfarmer
go to the tech articles section listed on the right side of the page. There is an article on brighter lights through the use of relays.
Old Jan 29, 2002 | 12:24 PM
jaye's Avatar
jaye
head light wiring
Thanks for all the respnoses I think I'll use my original headlight switch.
Old Jan 29, 2002 | 02:02 PM
Mac55's Avatar
Mac55
head light wiring
