That is how i pulled my 390 but the tranny was not connected i had dropped it earlier.....but considering the tranny is not all that heavy(well mine is not) I wouldn't think you would have any problems...JMO
the carb plate puller is 12.00 at AZ, Checkers, Kragen, Pep Boys, etc..not sure if it's designed to have the tranny attached as well weight/balance wise though.
If you have a leveler with hooks on the end.......just stick them in the exh ports on each corner. That's how I do mine everytime. NO fuss.
If not, maybe use exh port bolts to bolt chain to.
