High output heater???
Old Dec 6, 2006 | 01:10 AM
towtruck1's Avatar
towtruck1
I need to replace the heater core on my 78 f350, how do I know if I have a standard, or high output heater?? It does not have a/c. Thanks, Tim
Old Dec 6, 2006 | 05:39 AM
Desert Don's Avatar
Desert Don
If it is a High output heater-- it will say "HIGH OUTPUT HEATER" right on the heater control panel. Don
Old Dec 6, 2006 | 09:36 AM
1978fordf250's Avatar
1978fordf250
how much better is a high output heater? Also what is all involved in puting one in our trucks without them?
thanks,
Jimmy
Old Dec 6, 2006 | 10:37 AM
Desert Don's Avatar
Desert Don
If my info is correct- the "HIGH OUTPUT HEATER' on the late 70's model was really the standard heater up until about 76 or 77. Then they got the bright idea of putting in a smaller heater core for the " Standard" and now you know the rest of the story. Remember the TV commercial" Ford has a better idea" HaHa!!
I don't know what the chore would be to convert a standard to high output. Probably the easiest would be to take it to a shop and tell them to call you when they are done!! Good luck, Don
Old Dec 6, 2006 | 11:42 AM
Markcuda's Avatar
Markcuda
Question
If a guy has factory air, would he have the high output heater core=1977?
Old Dec 6, 2006 | 12:07 PM
LxMan1's Avatar
LxMan1
The heater core for a High output is wider than a standard one. I am pretty sure that it will fit in the standard heater box. I was going to put one in mine, but I had already bought the standard one.
Old Dec 6, 2006 | 02:52 PM
Mil1ion's Avatar
Mil1ion
There are 2 active threads on this topic right now.
Here's one of them.
https://www.ford-trucks.com/forums/5...terchange.html
access to back pages is at the bottom of the page
The whole heater assembly has to be swapped over as the regular core assembly will not house the Larger HO heater core.
Old Dec 6, 2006 | 08:24 PM
plowpusher's Avatar
plowpusher
there is only one heater core for ac it is different than the non ac heater cores the high output will say high output on the heater box/plenumn a high output core will not fit in a standard heater box .
Old Dec 7, 2006 | 10:59 PM
crewcabz's Avatar
crewcabz
The HO core will "fit" in the standard box, but there will have to be alot of mod. to get it to stay, and work properly. Most of the trucks that I have seen with HO heater do not have the option of cold (non-heated) air through the heater,(the heater core block off valve is not there) so the controls are even differant than standard (mostly crew cabs, built in Canada, so this may also be some of the differance). My '78 Crew Cab has the std. heater and it will cook you out with a 180 degre thermostat. I'd say there's no reason for the work of going HO (you don't live in Alaska do you) unless you happen to have all the needed pieces lying around abnd just want something to do. Happy motoring and good luck...Zeek
Rusty_S
Dec 12, 2016 10:17 PM
54Hydro
Nov 8, 2015 10:16 AM
bert cook
Jun 4, 2015 05:17 PM
trlawman
Nov 11, 2006 06:07 PM
natecousineau
Nov 7, 2004 01:28 PM
