Heater core
Old Dec 5, 2016 | 11:01 AM
Rusty_S's Avatar
Rusty_S
Heater core
Im thinking of replacing my heater core but i see theres a high out put. Wanted to ask if the high output will work in place of a standard out put unit without a/c. There is no mention of the high output being ac or non ac.
Old Dec 5, 2016 | 11:56 AM
82F100SWB's Avatar
82F100SWB
The core is larger on the hi o
Old Dec 5, 2016 | 03:24 PM
Rusty_S's Avatar
Rusty_S
Are they interchangeable or is the heater box under the hood different?
Old Dec 5, 2016 | 04:56 PM
Franklin2's Avatar
Franklin2
Box must be different, since it says "high output" molded into the box. I think we have come to the conclusion that the high output was only available without A/C. So if you have A/C, it's not going to fit anyway.
Old Dec 5, 2016 | 09:49 PM
iwals's Avatar
iwals
I don't know about the high output, but I do know from experience the heater cores for factory AC and non-AC are not interchangeable.
Old Dec 6, 2016 | 11:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980/86 F100/350 & Bronco:
E3TZ-18476-H .. Heater Core-Use with standard heater (6" wide).
E3TZ-18476-F .. Heater Core-Use with high output heater (7 1/2" wide).
E3TZ-18476-G .. Heater Core-Use with factory installed integral A/C or Hi/Lo Comfort Vent System.
Old Dec 6, 2016 | 03:45 PM
82F100SWB's Avatar
82F100SWB
Oops, looks like my computer ate most of my post. The Hi-Output unit uses a different box under the hood, it actually has hi-output embossed in it:
The cab side is the same, I put that one in my truck in place of a standard one.
Old Dec 12, 2016 | 10:17 PM
Rusty_S's Avatar
Rusty_S
Mine is a standard one. I took and ordered at work since it was slow from our local shop a replacement copper heater core for a standard truck. Figured since it was built/sold in Tx it wouldn't have the high output heater core. Sure enough I was right the standard core fit just right. I even took and sealed the blend door with some house hold foam strips that is tacky on one side.
I don't know what it was but I could flush the heater core out water would come through what I thought was very quickly and easily. But wouldn't put out much heat. New heater core the needle just starts to move up to the C mark on the temp gauge and its already blowing air as warm as it was after running for nearly an hour. I also saw staining pointing to a leak on the core. Probably where my coolant was going and why I kept having to add half a gallon to a gallon of coolant every 2 months or so.
bootless1075
Oct 21, 2018 09:07 PM
Drac
Dec 20, 2011 10:15 PM
MSC
Sep 1, 2006 04:36 PM
willydad
27
Dec 17, 2005 01:31 PM
bullnose
Oct 16, 2002 05:55 PM
