1978 - 1996 Big Bronco
Temperature
Old Dec 14, 2006 | 11:22 PM
Bimmerboy1989's Avatar
Bimmerboy1989
Oh yeah sometimes air gets trapped in the heater system, so make sure you turn your heater on when you are purging air from the cooling system. Also did you change the temp sending unit? if you did which one did you change, because there are two. One is two porng on the heater pipe, the other is single prong on the lowe intake. The single prong one is for the gauge. This is the one that will cause the fluctuation.
Old Dec 17, 2006 | 02:08 PM
RedRooster77's Avatar
RedRooster77
My mixture is 60/40. I dont know why the heat fluxuates but it's really pissing me off. I am about to take it in. Which I hate to do.
Old Dec 20, 2006 | 10:49 PM
RedRooster77
Wink
Well as it turns out the new thermostat I installed stirred up a bunch off sediment in the system. Most likely from being open all the time. I think that now that it was pressurizing more it pushed out a bunch of crap. I flushed it agian and the problem went away. Now the gauge is right around thte O to dead in the middle at the highest. I knew something wasn't right. Thanks for the Help All....
Old Dec 20, 2006 | 11:48 PM
Bimmerboy1989
Very interesting, makes sense though. Congratulations on finding the problem. Anyways good luck with your truck.
Cljw99
Mar 6, 2017 07:48 AM
Dwightttt
Apr 13, 2016 08:05 AM
timlange
Nov 26, 2015 06:52 AM
DaytonaTunnel
Jun 19, 2011 03:56 PM
Coalroller
Jan 2, 2010 09:45 AM
