when the truck first starts up everything is fine but whenever i drive some where and shut it off for a while then start it back up the engine runs fine but the rpm gauge reads 0 and the o/d flashes until i give it fuel and pull away then the gauge reads normal and flashing stops until i let off the pedal they drop back to 0 and the o/d light flashes again. the engine runs fine no studdering or anything like that after about 10 min or so of this its a 50/50 that the rpms will be normal on the gauge can anyone help?
yours will probably be under the vacuum pump like mine.its a pain but you can swap them without taking the vacuum pump off just be careful with the wires
