My Power Rear Sliding Window Got Stuck And Would Not Close.
I Have 2006 Ford F350 Crew Cab, Anyone Know How It Is Wired Is It The Switch Or The Motor? Anyone Knows If Power To This Window Goes Through The Main Window Switch On Drivers Front Door?
Any Help Would Be Appreciated
Thanks
As best I read the print it is fed by a 30 amp fuse in the central junction box,fuse 601and from there it comes thru the accesory timer.I tried to put the schematic on for you but could'nt figure out how to get it done.Check the fuses under the knee bolster.Good luckif i can help let me know.Tim
Thanks
advancemotors,
Go here and click on "Purchase Subscription" lower left hand side. You can purchase a 3-day ($9.95), 30-day ($16.95) or 12-month ($99.00) and then download all the service manuals and wiring schematics to your computer for future use.
