1994 Explorer Transmission Lines
Old Dec 5, 2006 | 10:20 PM
mikeinri's Avatar
mikeinri
Hi guys,
On my 1994 Explorer, I just replaced the rubber auto tranny cooler lines and changed the oil and filter. I was leaking transmission fluid, and it appears to be coming only from the area around those lines (transmission itself is dry).
After I finished, I noticed it is still leaking fluid a few days later. I got back under and noticed that the metal lines are very rusty (just above a crossmember and I didn't notice this before). I'd like to replace them, but have an important question.
Since I don't want a surprise shower while I'm under there, do I need to drain the pan again before I pull the metal cooler lines out of the tranny to replace them? Or, do they enter high enough on the tranny so they are out of most of the fluid?
Also, at the local parts stores, they only have "bulk" lines, I would have to bend them myself to match the originals. Does Ford sell them pre-bent? If not, are there plugs that I can place into the tranny while I'm bending the new lines so I don't lose too much fluid?
Mike
Old Dec 30, 2006 | 01:19 PM
unseenspirit's Avatar
unseenspirit
Your going to want to drain the transmission first before you go replacing lines.
Old Dec 30, 2006 | 03:45 PM
marragtop's Avatar
marragtop
You will have to bend the lines yourself. Ford dealers will tell that they only sell 'bulk lines' which means you have to bend them yourself. Much cheaper at any auto store. Pretty easy job. Make sure you soak the fittings with PBlaster or WD40 first.
Old Dec 30, 2006 | 07:40 PM
quicklook2's Avatar
quicklook2
if it has not run for a day nt too much will drain out.
lay down some plastic and rags and an oil drain pan or two.
i just did a sable's trans line and a water pump on my f150 with radiator out and only a little trans fluid poured out.
Old Jan 2, 2007 | 05:31 PM
mikeinri's Avatar
mikeinri
Thanks guys, Happy New Year!
Before I read these replies, I did check with the Ford dealer, they also confirmed the bulk line issue.
My bigger problem is that I'm losing more fluid than is showing up in the driveway, which makes me think the vaccuum modulator could be toast. I've also had lines blow off the vaccuum tree on occasion, though not recently.
I've posted a few questions about this, have any of you replaced this part, and do you have tips on how to best access the modulator part? The dealer said they would remove the exhaust pipes, etc.
Removing the exhaust sounds like overkill to me, especially since the pipes are original and we're over 260,000 miles (we all know that's a recipe for disaster, at work we call this SCOPE CREEP!).
Any suggestions from you here would be greatly appreciated!
Mike
Old Jan 2, 2007 | 06:52 PM
quicklook2's Avatar
quicklook2
chiltons does not say to drop exhaust.
only A4LD trans. use vacuum diaphram (modulator)
disconnect battery
raise vehicle and safely support it
disconnect hose from vacuum diaphram
remove bolt and clamp, do not pry on it
pull v.d. from case and remove the v.d. control rod from trans. case
install is reverse
80 to 106 inch pound on bolt
Old Jan 3, 2007 | 10:15 AM
quicklook2's Avatar
quicklook2
the ford repair cd does not say drop the exhaust either.
Old Jan 3, 2007 | 12:07 PM
marragtop's Avatar
marragtop
If yours is a 94, it IS an A4LD...
Old Jan 3, 2007 | 01:24 PM
quicklook2's Avatar
quicklook2
that is why i put the instructions for how to do it on an A4LD.
i am sorry if i was not clear.
JOE SKI
1997 - 2003 F150
Sep 13, 2014 09:15 AM
pawpaw
1983 - 2012 Ranger & B-Series
17
Apr 26, 2014 08:52 PM
smashclash
Dec 6, 2010 06:16 PM
truzoom
1997 - 2003 F150
Jun 6, 2010 08:09 AM
mikeinri
Nov 24, 2006 11:52 PM
