i got a 71 sport custom camper special
floating caliper front disk brakes.f350 front coil springs .coil over front shocks.f350 fear leaf springs.coil over rear shocks.dana 60 with 3.73s 245/75/16.mt/rs factory stainless steel camper mirrors that say ford .
360/c6 .do i have a real camper special.
vin #f25yrk10472
thank you
lrd56, The camper special is an add on package to assist with items that an owner would use with camping, including but not limited to
Larger capicity radiator and alternater, twin batteries, extra wiring, extra capicity suspention, and other items.
Usually if there is Camper Special badging out side and in, tis safe to presume that you own a CS.
When all else fails you have a heavy duty truck. IMHO
don't camper specials have 390 engines with 2 fuel tanks and a built in tool box on the outside passenger side of the box along with heavier duty leaf springs in the back?
Oscar, The truck could have come with a 300 6 in it, the other things usually, but not always.
Yes Twin Tanks/no Power 360/heavy Leaf Springs/bed Side Tool Box/thinking Of Having A Body Shop Put One On The Drivers Side/
Have A No Power 75 390 With 35000 Miles .valve Job Done Hard Seats Hard Valves.got To Wait Till Paid For.6 More Months.
Have A Good Day
my 71 has all the goodies .changed alternator to 90 amp one wire delco used stock ford brackets.drilledout bottom bolt hole to accept the bigger bottom bolt .used flat washers as spacers.who makes a bigger mirror than the 6 by 10 factory ones i cant see much of anything.yes i have 20/20 vision.
my 71 cs has a plug on the frame that looks like a big flat plug for camper electricial .local rv dealers dont have anything that matches.am i stuck going to the local ford dealer to find it .
have a nice day
I think the passenger side tool box was optional. I had a 73 camper special without it. I had a 73 trailer special with it.
Dual tanks were optional, not included with the c/s option.
