Sponsored by: Real Truck
Slow Power Window
Old Jan 3, 2007 | 09:50 AM
Sport45's Avatar
Sport45
Update:
I just got around to looking at this. Krewat was dead on! I was reluctant to try because I thought the lube would make a mess of my window, but a shot of silicone spray lube in the window channels fixed this right up. I used the tube that comes with the can to keep it in the channels and there's no mess on the window.
Thanks much!
Old Jan 3, 2007 | 04:40 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
All I know is what I've been reading on THIS SITE for the past 5 years
Mine is going slow now.
And before I burn out the motor or the switch (hint! hint!) I have to get around to doing this very same thing.
Anyone who didn't get the hint: It's very possible you had to replace the motor, because you kept your finger on the button trying to get it to go down.
Old Jan 4, 2007 | 08:13 AM
Mr Incredible's Avatar
Mr Incredible
Silicone spray worked for me!
I've been putting up with sticking windows for the last couple of years. I got around it by just not dropping them all the way.
I read this discussion, went out and sprayed it real good, and both sides worked like a charm.
I figured it was something easy like this since the windows went down with no problems as long as it was rainy out. I just never got around to doing anything about it.
Now we'll see how long this lasts.
Thanks, Guys!!
Old Jan 4, 2007 | 10:50 AM
krewat's Avatar
krewat
Of course, the lube could be covering a mis-aligned track. But certainly easier.
Old Jul 11, 2024 | 06:15 AM
BiGeE's Avatar
BiGeE
1st Gear
This is an old thread and im embarrassed to say it, but I've been putting up with a window on my 99 that wouldn't roll down past 2 or 3 inches without helping it for probably 7 years. I finally got sick of it and was looking at changing the motor when I found this thread. I tried the silicone for kicks and it works perfectly. I'm blown away
jnoble87
Jan 23, 2015 07:37 PM
pin8246
Oct 27, 2012 01:02 PM
PeterAL
Feb 1, 2011 09:00 PM
tip49
17
May 5, 2010 11:38 AM
jhromy
Apr 7, 2004 10:07 PM
