I've used white lithium grease on my car as well, works beautifully, don't get it on anything you're going to paint. The not staying up problem is the first I've heard of it, which also means I know nothing about that problem, lol.
In case none of the other ideas here work out for you, you might try some good old white lithium grease. Just a little in the roller tracks and gear teeth will work wonders. The stuff is good for about anything that ails you.
If your windows don't stay up, it's probably a matter of weak springs in the regulator, rather than the tracks being lubed properly.
Ross;
The manual calls for the felts; but mine must have been discarded or lost at some point. I've got some soft rubber washers that I am going to try; as long as they don't bind. The key would be allowing the arms to slide freely I suspect.
