Sponsored by: Auxito
F-150 Edge Evolution
Old Dec 4, 2006 | 09:28 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Anybody on here ever put a Edge Evolution w/attitude on there truck... I have a 4.6L and want a first hand thought of it.... It sounds pretty dang good and i just want to know if you can tell any differnce when you put it in or if its more power but youll never notice kinda thing...Also does it give you your average MPG and Instant...? Ive done quite a bit of research on it and it says that it does.... i guess i want to know if its accurate at all... Hopefully sombody has some input for me.... Thanks Alot...
Old Dec 5, 2006 | 08:47 AM
BURNSTOUGHFORD
Has anybody put any kind of programer on there 4.6l and noticed a difference?
Old Dec 5, 2006 | 12:05 PM
FordMan03's Avatar
FordMan03
I have an 03 f150 w/ 4.6L. I have a cold air intake, throttle body spacer, cat back, and Edge w/ attitude. Yes, there is a very noticable difference. It feels like a totally different truck. The most notice is in the tranny. It hits alot harder. MPG is better by 1-2. Just the ability to adjust anything from timing to shift points is worth it.
Old Dec 5, 2006 | 12:16 PM
BURNSTOUGHFORD
what octane do you run it on?
And what about the display of fuel milage...it says somthing about displayin a bunch of info?
Old Dec 5, 2006 | 12:41 PM
FordMan03's Avatar
FordMan03
It has 3 levels. Level 1 is stock, 2 is tranny only 87 octane + , level 3 is high performance 93 +, I always run 93. It says min of 93 for Level 3 but I have added booster and noticed a little difference. You can have up to four parameters displayed at a time. There is like 15 or so that you can watch.
Old Dec 5, 2006 | 09:15 PM
BURNSTOUGHFORD
one of the displays is average gas mileage? right
Old Dec 6, 2006 | 06:55 AM
FordMan03's Avatar
FordMan03
It can display:
RPM
MPH
Engine Coolant Temp
Cylinder Head Temp
Air Intake Temp
Engine Load %
Mass Air Flow
Spark Advance
Battery Voltage
Instantaneous Miles Per Gallon
Diagnostic Trouble Codes
Average MPG
And others I think. I told you wrong about the levels, let me correct myself.
L1 is tranny only, which you can change the firmness of shifts during regular driving and for wide open throttle. You can also change when it shifts (rpm).
L2 is towing mode, this is where the tranny adjustments will really help. You will really start to notice the power increase in this mode.
L3 is performance mode, this is where you can go all out ad adjust pretty much anything you could think of or want. I guarantee you will love the way your truck feels if you get one. I highly recommend it. A buddy of mine bought the superchips tuner when I got the edge and he told me straight up that there was no comparisson and that he regrets getting the SCT. I would suggest shopping around if you do decide to get one. You will definately find better prices than the ones on EDGEPRODUCTS.COM. Anything else?
Old Dec 6, 2006 | 08:28 AM
gui88ford's Avatar
gui88ford
i'm interested in one too....my truck is a 5 speed....so, you really do feel a difference in the power of the truck....mine is also a 4.6L....so, even if mine is a 5 speed if i put it on L2 i'll feel a difference in the truck and it's performance.....and L3 it's a noticable seat of the pants power gain...?????
Old Dec 6, 2006 | 10:10 AM
FordMan03's Avatar
FordMan03
I can't tell you enough how much better and stronger your truck will feel. Seat of the pants performance is amazing. Since I have had mine I took my truck to the dealer to have transfer case work done. At this time I had to set it back to stock and I hated it. Going from level 3 to stock felt like I was driving a Datsun or something.
Old Dec 6, 2006 | 10:18 AM
gui88ford's Avatar
gui88ford
very cool....i think i may look into it....thanks for the info...do you have any dyno #s for actual change in performance...
Old Dec 6, 2006 | 10:31 AM
FordMan03's Avatar
FordMan03
Unfortunately no I don't have any dyno #'s. I would really like to put it on one though. That's really the only way to get the most power out of your truck but I'm confident you won't be disappointed with the edge.
Old Dec 6, 2006 | 10:39 AM
gui88ford's Avatar
gui88ford
so, i'm assuming is adjusts timing curves and a/f ratio...things like that...
Old Dec 6, 2006 | 10:43 AM
FordMan03's Avatar
FordMan03
yes you can add or retard the timing. I wouldn't suggest adding more than 3 degrees though without having it on a dyno to watch more in depth parameters. You can also adjust WOT fuel Percentages.
Old Dec 6, 2006 | 11:51 AM
gui88ford's Avatar
gui88ford
yea, 3 degrees is about it...that was my next question.....is that abotu what you adjusted...or if you adjusted more what did you adjust.....WOT fuel percentages i wouldn't think would make much of a difference unless your adding timing to it..
Old Dec 6, 2006 | 02:43 PM
FordMan03's Avatar
FordMan03
I added 2 degrees of timing and bumped the wot fuel up 3%
