Electronic speedometer....
Old Dec 4, 2006 | 04:00 PM
Dragonfox13's Avatar
Dragonfox13
Ok, i have a 95' F150 and lost the speedometer/odometer in it about a 2 weeks ago, and have crawled all over the truck trying to determine if its wiring or something else?
The speedometer dosent move, and the odometer dosent even come on, and right now the OD light on the shifter is blinking.
any help would be appreciated.
Old Dec 4, 2006 | 04:10 PM
subford's Avatar
subford
You either have a bad VSS or wiring on the rear carrier or a bad PSOM.
Make sure you check all of the fuses both in the cab and engine compartment.
Old Dec 4, 2006 | 04:18 PM
quicklook2's Avatar
quicklook2
if you do need to remove your instrument cluster go to articles/specs at top of the page and find the write up on how to remove.
like subford says it is probably a bad vss or loose wire or dirty vss.
than look into the psom which is on the back of the instrument cluster.
Old Dec 4, 2006 | 04:26 PM
Dragonfox13
thanks for the quick reply, ill look into it
Old Dec 4, 2006 | 04:32 PM
doodaa's Avatar
doodaa
Was the VSS sensor on the top of the rear differential when mine went out. Check the wiring back there. My ABS light was shining too.
Old Dec 5, 2006 | 05:11 PM
Dragonfox13
ok, so from what im gathering the VSS being bad would also affect the Odometer and the Overdrive ?
Old Dec 5, 2006 | 05:52 PM
subford's Avatar
subford
Yes it would and the PSOM would too.
Old Dec 5, 2006 | 05:54 PM
Dragonfox13
so what is the PSOM exactly and what does it do? (car ignorant)
Old Dec 5, 2006 | 06:02 PM
subford's Avatar
subford
It drives the speedometer, odometer and sends speed information to the PCM (Powertrain Control Module). It gets its information from the VSS (Vehicle Speed Sensor or signal) on top of the rear carrier.
Here is a photo of the PSOM (Programmable Speedometer/Odometer Module):
http://i54.photobucket.com/albums/g91/subford/DSC02313.jpg
jim33067
Aerostar
Jan 29, 2014 09:01 PM
dannytilton
Sep 8, 2011 07:29 PM
dfarland
Sep 23, 2010 03:06 PM
GVS
Sep 28, 2007 12:02 AM
Double T Dave
Nov 29, 2004 08:32 PM
