fuel leak
Old Dec 4, 2006 | 11:18 AM
helpfulguy's Avatar
helpfulguy
fuel leak
I have a leaking fuel pressure sensor? the one that is on the filter housing. Is there any other place to get these things beside the ford house? I checked ebay but no luck, however i might be calling it the wrong name.
Old Dec 4, 2006 | 01:51 PM
helpfulguy's Avatar
helpfulguy
well after some thought i plugged it. And I will check with the International dealer the next time i go to san antonio.
Old Dec 4, 2006 | 01:58 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
I also would check with International. If it has a o-ring on it you just might be able to get the o-ring and fix it that way. I'm sure some body will pop on here and get you a part # for it soon. Good luck!
Old Dec 4, 2006 | 04:46 PM
helpfulguy's Avatar
helpfulguy
no o-ring. looks like an oil pressure sending unit but i bet the spring is set at a lower psi. I could not believe that the aftermarket parts guys don't have this thing but they don't. But i feel a lot better about my truck now. I thought i had a bad oil leak at the pan but turns out it was mainly fuel, so i don't have to pull it just yet.
Old Dec 5, 2006 | 11:48 PM
FordPowerStroke's Avatar
FordPowerStroke
I've got a fuel leak that just popped up. It is coming somewhere just aft of my fuell filterr housing. I really can't see where it is coming from though. Could this be the same thing?
Old Dec 6, 2006 | 08:31 AM
helpfulguy's Avatar
helpfulguy
could be. but mine was dripping straight down from the drivers side of the filter assembly . i had to use a little flashlight and basically lay on top of the thing with it running to find the drip. mine was leaking through the switch and was dripping from were the wire plugs into it at. so it is possible that depending on the routing of the wire it could follow that and then drip off somewhere else i guess.
Old Jan 17, 2007 | 12:17 AM
F350_Hauler's Avatar
F350_Hauler
Fuel Filter Restricted Sensor(looks like a small oil pressure sender). Get it at International for $15 part#1809435C1
Old Jan 17, 2007 | 07:46 AM
BEECHBM69's Avatar
BEECHBM69
The only way to know for sure is to clean it up real good to find out where it's coming from. Fuel in the valley back that far is generally the fuel pump going out and leaking from the weephole. Hope you get it worked out.
Dan
Old Jan 17, 2007 | 09:42 AM
helpfulguy's Avatar
helpfulguy
thanks f350_hauler i will pick one up as soon as i can. been running with it plugged for now.
Old Feb 25, 2007 | 03:24 PM
FordPowerStroke
How difficult is it to replace a fuel pump? I'm no mechanic but pictures of a new fuel pump look like you plug 4 hoses. Can a rookie do this?
Old Feb 25, 2007 | 04:37 PM
14psd's Avatar
14psd
FordPower, anyone can do it, besides what could go wrong? Right. It just takes patients. Try this link it should help https://www.ford-trucks.com/forums/5...ight=fuel+pump. I have done other repairs to my truck from this site and all has been good. I have to do the fp myself, I just haven't had time. This coming weekend is when I plan on doing it.
Old Feb 26, 2007 | 10:07 AM
F350_Hauler
You can do it....
Yes a rookie can do this. Just be careful when you undo the pump and move it off its perch. Do not drop the pump pushrod down into the engine block. You can minimize the possibility of this happening by turning the engine over by hand with a large socket on the crankshaft so that the camshaft is at the top of its stroke. Undo the bolts for the pump but leave it stuck in place until the turning engine lifts it off the gasket.
Old Mar 4, 2007 | 09:04 PM
risky97psd's Avatar
risky97psd
hi guys i also have a fuel leak. where is the weep hole on the fuel pump? also id like to power wash the top of the engine. if i drive it to town (about 10 miles) to the quarter car wash would i do any harm if the cold water hits the turbo housing? thanks
Old Mar 4, 2007 | 09:51 PM
RubberDuck's Avatar
RubberDuck
Man..........where were you 3 weeks ago!!! The ford house calls it a vaccum switch. It's the sensor that turns on the water in fuel light. I didn't even think about going to international for it. DAMN IT! I paid $74 for mine. But no more leak!!! I too thought it was the fuel pump. So I bought one of those too. Oh well, I guess I'm ready when it does go.
brojrm
27
Jun 11, 2024 07:02 AM
dampink
Jun 9, 2015 08:25 PM
Stephenn95
Apr 19, 2015 01:01 PM
jimwilsonmasonry
Jul 14, 2008 04:18 PM
fordfan28
Aug 24, 2007 05:06 AM
