does it only do this when its cold? if so it could be a glow plug or just cold oil. If its cold oil we normally call that a romp. I switch to rotella 10W30 for the winter. many other use 5W40 synthetic to cure romps also.
na, that should not be the problem, as i live in florida. all i know is it imbarasses the hell out of me. it seems to only do it when someone is admiring, or has just commented, questioned my truck.i'll fire it up and whomp,whomp,whomp.....
I have the same lope that some of you have talked about . As far as i know i don't have any the the 10-18k mods ,so TJBEGGS fix won't help me i don't think..thanks for all the posts though Very Helpfull !!!!!!!!! Any other idea's ? I made a post STRANGE START UP you can see a post someone made, about shimming the CPS anyone have that fix the problem ?
I got a new new down pipe, straight exhuast, intake, 4 pos chip from Dale Isley at Tymar Performance.
I was giggling at all the romp romp talk. I went out there this morning and guess what.....romp, romp,romp.....about four times and then smoothed out. It was about 30 degrees last night.
Then again tonight when I fired her up after sitting for a while in 45 degrees.......romp,romp,romp,romp, then smooth sailing.
WTF?
I have some other issues since themods, but I don't want to hijack this thread.
I still love my truck, the romping is actually kinda cool as long as it does not get worse. I just hope it is not causing problems or synptomatic of a problem.
Hey guys, great news!!! I have another thread going that I started before I found this one. It is titled "96 powerer storke idle problem." The guys over there found my problem. It was the Transmission Selector Sensor on the side of the transmission. Mine would start fine in neutral, but romp romp romp in Park. I put a different one on last night and now it works fine. I also cleaned the speed sensor in the transmission and now it shifts a lot better. Hope this helps.
many times the cold weather romp is from thick oil. plug in the block heater and it will probably not romp. The romp spoken of here happen not matter if it hot or cold. your truck unless it has the same problem probably won't romp when it warm.
