1964 headers
Old Dec 3, 2006 | 06:24 PM
Voh's Avatar
Voh
1964 headers
Has anyone had any luck with installaling/Finding headers for a 1964 F-100. I am installing a 460 and would like headers if possible. Could any other years work?
Old Dec 3, 2006 | 08:21 PM
Customcab's Avatar
Customcab
I'm sure someone know's the right answer, and will chime in but; I will just give you some though answer/ questions.
I recommend shorty headers; which are common for 460's etc. The reason is clearance of other accessories, like steering, starter etc. Having a straight axle makes things easier in IMO, so even long tubes could be the answer. Have I confuse you yet?
Mitch
Old Dec 3, 2006 | 09:04 PM
FordBoypete's Avatar
FordBoypete
If you are using a 64 chassis you may need to get custom headers like those used on 4X4a which go outside frame rails due to the way steering is on 64s. You may have a slight problem. Air Harley has a 385 in his 63 he can get you straightened around.
As I told you B4 that chassis runs from 57 thru 64, the others are 65-79. Those are where later engines are bolt in interchangeable. There will be no other "off the shelf" headers that fit your application. They will be application specific because of chassis/steering design & layout restrictions I believe.
http://www.landlproducts.com used to make them I think, they're pricey tho
FBp
albert leo janssens
May 20, 2026 10:43 PM
Dave King
Feb 13, 2013 02:23 PM
Caruso72
Oct 17, 2012 12:42 AM
james gang 1001
Apr 12, 2009 02:33 PM
dullchrome
Jan 22, 2009 12:48 PM
