Sponsored by: Kumho
ABS code 15?
Old Sep 5, 2005 | 03:47 PM
Gr8ride's Avatar
Gr8ride
ABS code 15?
Hi
The ABS light is flashing a code 15 on my 93 F250 7.3L.
From what I have read that code means memory failure.
What do I need to do to fix it?
Thanks,
Gr8ride.
Old Sep 6, 2005 | 10:13 PM
peppermrj's Avatar
peppermrj
Post
Originally Posted by Gr8ride
Hi
Thanks,
Gr8ride.
<TABLE width=566 border=1><TBODY><TR><TD align=middle width=28>
15
</TD><TD align=middle width=63>
(O)
</TD><TD align=middle width=453>
No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
</TD></TR></TBODY></TABLE>
<TABLE width=566 border=1><TBODY><TR><TD align=middle width=63>
(M)
KAM (pin 1) was interrupted (was battery disconnected ?)
</TD></TR></TBODY></TABLE>No personal experience but I would check battery power to pin 1. Good luck
Old Sep 6, 2005 | 10:23 PM
peppermrj's Avatar
peppermrj
To clear KAM (keep alive memory), disconnect and isolate negative battery cable for a minimum of five minutes. After clearing memory, it is necessary to drive vehicle a minimum of 10 miles to allow processor time to relearn value.
I'm not sure this code is for abs. Cant find anything on the net.
Gr8ride
Sep 25, 2009 02:49 PM
Gr8ride
Aug 23, 2005 04:09 PM
Gr8ride
19
Mar 23, 2004 11:14 AM
Gr8ride
Aug 29, 2003 07:54 PM
Gr8ride
Apr 13, 2003 09:30 PM
