elec fuel pump orientation
Old Dec 7, 2006 | 11:06 PM
  #31
catfish101's Avatar
catfish101
I have put several electric pumps on Fords with 6.9's and 7.3 and the pump I used is a GM pump for a 6.5. The P# is EP309. They are not expensive. I haven't seen one I put on fail yet. We had GMC medium duty trucks, also, at the dealer I worked at and we rearly saw one of these pumps fail. They go inline, pull low voltage. They are a pulse pump. I use one now for priming fuel systems on trucks I work on now. It is a handy "tool" to have around just to pump fuel out of something. You can make a cover to go over the hole. Any thin piece of metal will work.
Old Dec 7, 2006 | 11:39 PM
  #32
CheaperJeeper's Avatar
CheaperJeeper
Originally Posted by 2jhanna
dave7.3, i replaced a mech fuel pump on a `74 f-100 gasser, after 20 years that was still good. i was planning a 22 hour trip in it so i replaced a lot of stuff at the time.
i think it was dave sponaugle stated a while back in a simliar thread that he had not replaced a lot of mech pumps. (i might be wrong on who said it though).
when i added a electric pump a couple of months ago, a did not want to chop a lot of fuel lines either, i mounted mine beside the mech pump on the frame rail and removed the existing rubber line from the mech pump, hooked it to the electric pump and another rubber line to the steel line. no cutting involved.
one of the beauties with this is that both pumps are side by side and it is real easy to bypass either one if needed.
also, i did not get a diesel bath at all !!!
I like the sound of doing it this way. My only question is whether the mechanical pump diaphragm will hold up to "dry pumping" for extended periods of time. If not, and you go to hook it up if/when the electric fails, you may find that it has failed too.
Maybe you could leave it full of fuel and hook a line between its input and output and let it just recirculate the fuel internally to avoid damage due to dry pumping.
Old Dec 8, 2006 | 06:22 AM
  #33
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Correct me if I'm wrong but the mechanical pump shouldn't need fluid for any reason. I really like this idea but was concerned about two things, one Cheeper mentioned, the other was the open 'in' port, for this I figured I would use a pneumatics exhaust. the only reason I could see the mechanical needing fluid would be just to keep the diaphram from drying out??
Old Dec 8, 2006 | 09:48 AM
  #34
CheaperJeeper
My concerns were for it drying out, but even more for it heating up. Normally, moving fluid would help to keep it cool. I'm wondering if the constant flexing of the diaphragm with no fluid to keep it cool might result in heat buildup damaging the diaphragm. Kind of like an under-inflated tire being run at high speed. The lack of air pressure isn't what causes the tire to fail - its the heat buildup from the sidewalls flexing too much. Just wondering if the pump diaphragm might not have the same kind of problem if it is run dry for months on end.
The possibility of it sucking dirt, water, etc. into the input port is also a concern that would be addressed by connecting the input and ouput ports....
Old Dec 8, 2006 | 04:41 PM
  #35
fellro86's Avatar
fellro86
I would guess you owuld be right about that, between heat and drying out, I doubt the diaphragm will last. Mechanical pumps don't tend to fail regularly, but neither do the electric. Mine was more of a convienience of priming than anything, and a couple times I push my luck too far and run dry, it has really saved my behind. It primes up fast, crank a bit to clear the lines, and we're off.
It may not be as big an issue with diesel, but the electric pumps are best placed close to the tank. It may be such that diesel is heavy enough that it isn't as big a problem as with gas, since you can't vapor lock a diesel...
Old Dec 23, 2006 | 11:47 PM
  #36
turboidi's Avatar
turboidi
block off plate from big block chev ,i mounted my pump just under driver seat with a big block ford filter before pump, power from ip when key turned on works great
Old Dec 24, 2006 | 12:21 AM
  #37
Pele's Avatar
Pele
So you only need ONE pump even if you have two tanks? The pump is strong enough to pull through the selector valve and up the line?
Old Dec 24, 2006 | 08:11 AM
  #38
fellro86's Avatar
fellro86
considering that is the way the factory did it... it will work just fine.
Old Dec 24, 2006 | 10:46 AM
  #39
harleyjohn45's Avatar
harleyjohn45
when i bought my 91 ford 3 years ago it had an electric pump with a toggle switch, i assumed it was to be used for priming the mechanical pump. but i soon found out the truck wuold not start unless the electric pump was on. so i bought a new mechanical. same problem, so i removed the mechanical all together and blocked the hole. best thing i ever did, i don't know how old the electric pump is, but it sure works good.
dakotajeep
16
Sep 19, 2011 10:37 PM
B 3000
1983 - 2012 Ranger & B-Series
Mar 12, 2009 09:18 PM
lrd56
Apr 19, 2007 11:20 AM
hart
Jul 12, 2005 06:15 AM
watermanh
Jun 20, 2005 09:10 PM
