Alternator
Old Dec 2, 2006 | 07:16 PM
Dj300ford's Avatar
Dj300ford
Alternator
I am putting in a new Alternator in my 83 5.0 Bronco well the one i got has connections for a FLO and STA on the back which one my voltage regulator go to, and what does each of them do?
Thanks
Old Dec 2, 2006 | 08:57 PM
Franklin2's Avatar
Franklin2
It should be FLD and STA. Here's a diagram.
FLD is the field terminal on the alternator. The regulator puts more or less voltage on this terminal, and that varies the output of the alternator and how much it charges the battery. If you are unsure if the regulator is bad, or the alternator is bad, a good test is to take the FLD wire off the alternator, and put a temporary wire from the bat + to the FLD terminal. This will make the alternator go wide open charge, and you will see the voltage rise way up at the battery with a meter hooked to it.
The STA is the stator terminal. It's hooked to the windings inside the alternator, and is sometimes not used. If you have a charge light in the dash, then the STA terminal is used. It's also used to power the factory electric choke on the carb.
Tyler S
May 4, 2014 10:48 PM
yerblor
Aug 1, 2011 11:09 PM
powerstroke1869
May 6, 2011 01:44 PM
lasthighboy
Electrical Systems/Wiring
Nov 30, 2008 05:07 PM
